Rock Pi X Does Not Poweron Upon Restore
A previous ticket outlines there are a few case scenarios where the system does not poweron upon power restore.
The OP notes:
“In the BIOS there is a setting “State After G3” where “S0” should mean the device is turned on after it gets power and S5 (default) means that the system would remain in shutdown state. However setting this to S0 doesn’t seem to help. I have installed the RTC battery.”
“While I was testing I used the power button to turn the system off gracefully. It turns out that Rock Pi X does remember this: If the system was turned off via the power button, it will not turn on automatically if the power gets cut and later restored. However if the power is just cut and restored the Rock Pi X will boot automatically.”
Another user notes:
“I had the exact same issue, however until I removed the RTC battery I was unable to get the device to power on when AC power was restored. After temporarily disconnecting the RTC battery the device powers up when AC power is restored.”
Does @radxa anticipate having a BIOS update for a potential workaround? There are use cases where this feature would be desired. The current solutions pose two problems:
  • RTC removal is problematic where RTC use is desired
  • System power state does not provide automatic poweron when external switch is used
Thank you,
I have the same problem :frowning: When RTC battery is connected when I plug off the power cable and then after few minutes when I connect it back it do not start automaticaly :frowning: State s0 in bios do not help)
s
I, like these other folks need this problem fixed before I can consider going forward using the Rock Pi X product. The Rock Pi X w/Windows 10 does not start up when power is applied and an RTC battery is installed. You always have to hit the reset button. I am currently using the BIOS from 9/24/2020, which I believe is the latest, and no matter what I try for BIOS settings this does not change. Can you discuss if an effort is being made to fix the BIOS or if the source code and tools to repair the BIOS ourselves is available? I would really like to use this product but this is a show-stopper.
