Thank you a lot.
Rock pi s debian ftdi driver missing
Hello, I use this image and have some trouble with shutdown.
1)install images on 6 pis
2)go to shutdown each pis, each pis have different command
sudo shutdown now
sudo shutdown -h now
sudo shutdown -P now
sudo poweroff
sudo halt -p
sudo init 0
everything was okay and work/
3) sudo apt update && sudo apt upgrade -y (in each pis)
4) sudo reboot (all pis)
5) do step 2 and pis dont work, ()
I have just tried the same procedure on one of my Rock Pi S with shutdown -h now
and it: updated, upgraded, rebooted and is still successfully shutting down after the process.
One thing, although it should not matter at all IMHO, is that I used the latest image from this topic: Rock Pi S Armbian Buster minimal (pre-release). It is a bit newer than this one.
Thanks, for answer.
I install that image, and in newer version I havent this problem, but I have problem with docker.
Oh. I never optimised it for docker
but previous version haven’t problem with docker -_-
and I in small confusion, in old version have problem with shutdown, in newer problem with docker
in this point, I think better way is resolve problem with docker/
That’s interesting
What problem with docker is it exactly? Can you attach error log?
yes, sure/
sudo systemctl status docker.service
- docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2019-11-19 21:02:36 +03; 3min 5s ago
Docs: “link”
Process: 1094 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 1094 (code=exited, status=1/FAILURE)
Nov 19 21:02:36 user11 systemd[1]: docker.service: Service RestartSec=2s expired, scheduling restart.
Nov 19 21:02:36 user11 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 19 21:02:36 user11 systemd[1]: Stopped Docker Application Container Engine.
Nov 19 21:02:36 user11 systemd[1]: docker.service: Start request repeated too quickly.
Nov 19 21:02:36 user11 systemd[1]: docker.service: Failed with result ‘exit-code’.
Nov 19 21:02:36 user11 systemd[1]: Failed to start Docker Application Container Engine.
Nov 19 21:03:03 user11 systemd[1]: docker.service: Start request repeated too quickly.
Nov 19 21:03:03 user11 systemd[1]: docker.service: Failed with result ‘exit-code’.
Nov 19 21:03:03 user11 systemd[1]: Failed to start Docker Application Container Engine.
docker version
Client: Docker Engine - Community
Version: 19.03.5
API version: 1.40
Go version: go1.12.12
Git commit: 633a0ea
Built: Wed Nov 13 07:28:11 2019
OS/Arch: linux/arm64
Experimental: false
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
sudo apt install -f docker-ce
Reading package lists… Done
Building dependency tree
Reading state information… Done
docker-ce is already the newest version (5:19.03.5~3-0~debian-buster).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up docker-ce (5:19.03.5~3-0~debian-buster) …
Job for docker.service failed because the control process exited with error code.
See “systemctl status docker.service” and “journalctl -xe” for details.
invoke-rc.d: initscript docker, action “start” failed.
Active: activating (auto-restart) (Result: exit-code) since Tue 2019-11-19 21:14:38 +03; 47ms ago
Docs: “link”
Process: 1762 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 1762 (code=exited, status=1/FAILURE)
Nov 19 21:14:38 user11 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 19 21:14:38 user11 systemd[1]: docker.service: Failed with result ‘exit-code’.
Nov 19 21:14:38 user11 systemd[1]: Failed to start Docker Application Container Engine.
dpkg: error processing package docker-ce (–configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
journalctl -xe
- A stop job for unit docker.socket has finished.
– The job identifier is 1077 and the job result is done.
Nov 19 21:14:48 user11 systemd[1]: Stopping Docker Socket for the API.
– Subject: A stop job for unit docker.socket has begun execution
– Defined-By: systemd
– Support: link
– A stop job for unit docker.socket has begun execution.
– The job identifier is 1077.
Nov 19 21:14:48 user11 systemd[1]: Starting Docker Socket for the API.
– Subject: A start job for unit docker.socket has begun execution
– Support: link
– A start job for unit docker.socket has begun execution.
Nov 19 21:14:48 user11 systemd[1]: Listening on Docker Socket for the API.
– Subject: A start job for unit docker.socket has finished successfully
– Support: link
– A start job for unit docker.socket has finished successfully.
Nov 19 21:14:48 user11 systemd[1]: docker.service: Start request repeated too quickly.
Nov 19 21:14:48 user11 systemd[1]: docker.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– Support: link
– The unit docker.service has entered the ‘failed’ state with result ‘exit-code’.
Nov 19 21:14:48 user11 systemd[1]: Failed to start Docker Application Container Engine.
– Subject: A start job for unit docker.service has failed
– Support: link
– A start job for unit docker.service has finished with a failure.
– The job identifier is 1016 and the job result is failed.
Nov 19 21:14:48 user11 systemd[1]: docker.socket: Failed with result ‘service-start-limit-hit’.
– Support: link
– The unit docker.socket has entered the ‘failed’ state with result ‘service-start-limit-hit’.
Nov 19 21:15:01 user11 CRON[1955]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 19 21:15:01 user11 CRON[1954]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 19 21:15:01 user11 CRON[1962]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 19 21:15:01 user11 CRON[1965]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 19 21:15:01 user11 CRON[1955]: pam_unix(cron:session): session closed for user root
Nov 19 21:15:01 user11 CRON[1954]: pam_unix(cron:session): session closed for user root
From what I could see on my install netfilter module is missing.
I will take care of it.
Hello, today update my pis with this 4 drivers :
- linux-buster-root-legacy-rockpi-s
- linux-dtb-legacy-rockpis
- linux-image-legacy-rockpis
- linux-u-boot-rockpi-s-legacy
then unistall and install docker, but have the same problem.
What exactly have you changed? I assume you reboot before trying again?
yes sure, make it for difference pis, 2 pis install like new(new image, update, etc)
OK, What do you get by executing this script:
wget https://raw.githubusercontent.com/docker/docker/master/contrib/check-config.sh
sudo bash check-config.sh
Docker is now broken on Rock Pi S
I will fix it over the weekend.
@igorp Could we re-spin the build of buster image for it then?
Sure, ping me when its ready. There will be some delay since I am travelling.
If package update is good enough - upload fixed deb packages with version 19.11.4 here:
warning: /proc/config.gz does not exist, searching other paths for kernel config …
info: reading kernel config from /boot/config-4.4.198-rockpis …
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: missing
- CONFIG_NET_NS: missing
- CONFIG_PID_NS: missing
- CONFIG_IPC_NS: missing
- CONFIG_UTS_NS: missing
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: missing
- CONFIG_BRIDGE: missing
- CONFIG_BRIDGE_NETFILTER: missing
- CONFIG_NF_NAT_IPV4: missing
- CONFIG_IP_NF_FILTER: missing
- CONFIG_IP_NF_TARGET_MASQUERADE: missing
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: missing
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: missing
- CONFIG_NETFILTER_XT_MATCH_IPVS: missing
- CONFIG_IP_NF_NAT: missing
- CONFIG_NF_NAT: missing
- CONFIG_NF_NAT_NEEDED: missing
- CONFIG_POSIX_MQUEUE: enabled
- CONFIG_DEVPTS_MULTIPLE_INSTANCES: missing
Optional Features:
- CONFIG_USER_NS: missing
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: missing
- CONFIG_MEMCG_SWAP_ENABLED: missing
- CONFIG_MEMCG_KMEM: enabled
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: missing
- CONFIG_IOSCHED_CFQ: enabled
- CONFIG_CFQ_GROUP_IOSCHED: enabled
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: missing
- CONFIG_CGROUP_NET_PRIO: missing
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_NF_TARGET_REDIRECT: missing
- CONFIG_IP_VS: missing
- CONFIG_IP_VS_NFCT: missing
- CONFIG_IP_VS_PROTO_TCP: missing
- CONFIG_IP_VS_PROTO_UDP: missing
- CONFIG_IP_VS_RR: missing
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
- “overlay”:
- CONFIG_VXLAN: missing
- CONFIG_BRIDGE_VLAN_FILTERING: missing
Optional (for encrypted networks):- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: enabled
- CONFIG_CRYPTO_SEQIV: enabled
- CONFIG_CRYPTO_GHASH: enabled
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: missing
- CONFIG_XFRM_ALGO: enabled
- CONFIG_INET_ESP: missing
- CONFIG_INET_XFRM_MODE_TRANSPORT: missing
- “ipvlan”:
- CONFIG_IPVLAN: missing
- “macvlan”:
- CONFIG_MACVLAN: missing
- CONFIG_DUMMY: missing
- “ftp,tftp client in container”:
- CONFIG_NF_NAT_FTP: missing
- CONFIG_NF_CONNTRACK_FTP: missing
- CONFIG_NF_NAT_TFTP: missing
- CONFIG_NF_CONNTRACK_TFTP: missing
- “overlay”:
- Storage Drivers:
- “aufs”:
- CONFIG_AUFS_FS: missing
- “btrfs”:
- CONFIG_BTRFS_FS: missing
- CONFIG_BTRFS_FS_POSIX_ACL: missing
- “devicemapper”:
- CONFIG_BLK_DEV_DM: missing
- CONFIG_DM_THIN_PROVISIONING: missing
- “overlay”:
- CONFIG_OVERLAY_FS: missing
- “zfs”:
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
- “aufs”:
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
It should be enough as it is kernel only. I will do that.
@sudoom I will give you a shout when it’s ready.
ty, i’l be wait/
Try now.
apt update & apt upgrade
