my one of my Rock 5B (V1.42) does not boot from a SD Card, there is even no output real on the Serial console, only ffffffffffcfcFfFff3f3f3f3f3f3f33ff3f, nothing more. I tried to start the maskrom mode by pressing the button and holding it, while I insert the USB Cable into the PC. The device is not recognized not on windows or linux. Is there any chance to recover this board or is it bricked by delivery?
I’m having the same symptoms as the OP. In my case I was trying to boot with MMC, and can’t see any output on serial console (maybe it’s my UART cable). Green LED turned on, but blue LED never turned on after a long wait. eMMC was partitioned correctly as I can verify them on a Linux machine. Both Linux and Windows can’t see any devices in maskrom mode (green LED on).
I’ve contacted Allchina and they suggest this might be PD issue, so I tried a fixed voltage DC 12V 3A barrel jack to USB-C, but same symptoms as with PD…
I can confirm that PD is not working, I need to use a 9V constant Voltage Source, with lower then 6V it’s quite unstable. But the defect board, does not even response with 9V supply.
My board have same symptom. I bought DP adaptor which support 9V and 3A.
But it doesn’t work with my Rock 5B.
Only Green LED turned on, no blue LED light and No Output.
Of note: the Rock 5B seems to prefer the SD card to the SPI for loading the initial boot loader. Because of this, the official Debian image written to an SD card will boot even with the SPI flash erased, and can be used to then recover the SPI.
(However, this also means that Debian booted from SD will not benefit from flashing a newer SPI image, as it never actually touches the SPI; execution jumps straight from the mask ROM to the boot loader on the SD card.)
Without eMMC, without sd card, and empty spi flash, if plug the USB C to PC, no maskrom is detected, it’s means the board maybe defective. Please contact the distributor for an RMA.
I wrote Allnetchina and got the request to send it back, I will try this in two weeks, first I have to find a shipping parcel where the costs not half of a price of a new one.
I also have one out of a batch of 6 that’s failing pretty much anything. It blinks between green and blue. Have not been able to use maskrom correctly on it. Might be my fault I am still trying to make sure I Have a cable that I am 100% is USB 2.0.
Maskrom not working also for me. I press the maskrom button, keep it holded, connect the board with another pc with usb-c-to-usb-c cable, release button, and run the tools. No device found, ? try many times, same result.
I’m very disappointed by this board, only problems (I’m not alone by reading this forum), I can’t understand how such a product can be sold: buy the board, emmc, nvme, power supply, all the necessary to have this results… bah
I’m having the same issue. Tried multiple power supplies including a bench supply which supplies through the USB C port, nothing, just boot loops using an SD card and debian image. There has to be a way to fix this without RMA’ing. What’s the cause of this issue?
12V, but this is a bench supply, so I can make it whatever I want. I really don’t think this is a power supply issue. In fact, this board was working, running for several days, and then I changed the image on the SD card and it just wouldn’t boot after that. I’ve tried pretty much any and every image available, including the new dietpi image.
