Can you please tell me how to connect properly DSI screen and run it together with original image of android 11 from radxa git repository?
I know it is can be done, as I sow post here where person was unable to turn the screen, but I tried to do so from ADB shell and did not find that ls /sys/class/drm/card0-DSI-1 and it is does not exist in that dir of android 11 I was able to download. Did not find any other info on how I can run it.
Can you please give me instructions for step by step or link where I can find all information.
Do anyone who already using any Radxa DSI screen with Rock4 and android…
Can you please give me any instructions on how to do that? Or link for instructions
where sad what needs to do/install/type to run them together, please?
I can see you are very busy. I got both screens and I got also Rock 3B and Rock 4C+ boards. Mostly interested to run android 11 on Rock 4C+ and any of Radxa DSI screens. I hope if I will understand on if I will know how to run setup on one of the screens, I will understand how to run both screens.
Thank you for your reply. Sorry, I was away for some time. Can you please tell me more about this file?
Where do I download it?
Which command I need to type to run it? Or how this command called?
I got manual on how do I copy it to the board. But the rest is a bit complicated secret for me.
I just tried this image. Screen turned lights strait away. But It had screen roads like it is broken. I already seen that when 4c+ had different overlays and 10HD screen did not worked at all.
Unfortunately I am really stacked. I cannot find the overlay for android(do overlays from linux get’s accepted?) and also I tried to build my own android image following instructions on website and did not get luck. Unfortunately overlay you provided do not work properly, and I am not able to connect through adb shell to the image I’ve downloaded.
Definitely I am missing simple and easy accessible information, as I know that people use android with this screens. Please, give me at least the way or link where do I will be able to finish this task.
