Rock 3A/3B RK3568 GPU Drivers
Have trialed and error many different methods but I cannot get either OpenGL or OpenGL ES acceleration working on my Rock 3B or my Rock 3A(have tested both) with my personal Armbian images. I have tried setting up both libmali(from JeffyCN) and panfrost using rkr 4.1 kernel source(Linux 5.10.160) from radxa but neither works.
For libmali, I tested both the g13p0 x11 libraries(for Mali G52) and g2p0 x11 libraries(gor Mali G52) on Debian 12 XFCE desktop(Armbian). With g13p0, I boot to a non-blinking cursor on a black screen, no progress after several minutes. With g2p0, I am able to boot into XFCE desktop and login, but colours are funny(what is supposed to be red colour is rendered blue, e.g. Armbian’s logo). Also, with g2p0, once I launch anything with GL ES 2, e.g. es2_info or es2gears-x11, the desktop crashes and logs me out so I have to log in with my password again. So obviously OpenGL ES with libmali is not working.
For panfrost, I set CONFIG_PANFROST=m and disabled CONFIG_DRM_IGNORE_IOTCL_PERMIT in kernel config, but when booting, the kernel gets stuck on ‘panfrost: finding power supply in device tree’(boot animation with Armbian logo gets stuck too, the spinning circle stops spinning and freezes). Is there an issue with panfrost on rkr4.1 kernel source? I’m booting panfrost-enabled kernel with Debian 12 image that has Mesa 22.3, which supports panfrost, so it’s not the same issue as this thread about Rock 3B CLI build.
To test further, I compiled Armbian Debian 12 with Armbian’s rockchip kernel source and Armbian’s rk35xx kernel config and panfrost works just fine(boots into desktop, glxinfo -B shows panfrost as the OpenGL renderer). So is this panfrost broken on rkr4.1 kernel source? I see that Armbian rockchip repo uses rkr6, could that be the difference?
I’ve also tested radxa’s official b18 image for Rock 3B and I can see that libmali is set up properly and works, es2_info shows Mali g2p0 as the OpenGL ES renderer and I can run es2gears-x11 successfully. Can anyone explain how the b18 image setup libmali? Seems like I didn’t set up libmali correctly(I generated deb packages using ‘debuild -uc -us’ and installed the g52-g2p0-x11-gbm deb).
TLDR: Anyone has a guide on how to setup libmali properly with radxa’s Linux 5.10 rkr4.1 kernel source? Must I be on Debian 11(I’m on Debian 12)? Also, does anyone know why panfrost on radxa’s Linux 5.10 rkr 4.1 kernel source causes kernel to freeze during boot?
Figured this out. Here’s a guide on getting GPU acceleration on Linux 5.10 radxa’s rkr 4.1 kernel:
*Clone Armbian’s build system
*Change the kernel source for rk35xx legacy to radxa’s rkr 4.1:
→ In build/config/sources/families/rk35xx.conf, change these lines:
KERNELSOURCE='https://github.com/armbian/linux-rockchip.git' KERNELBRANCH='branch:rk-5.10-rkr6'
→ To these lines:
KERNELSOURCE='https://github.com/radxa/kernel.git' KERNELBRANCH='branch:linux-5.10-gen-rkr4.1'
*Add this file rk356x-panfrost-fix.patch to the folder build/userpatches/kernel/rk35xx-legacy:
 diff --git a/arch/arm64/boot/dts/rockchip/rk3568-rock-3b.dts b/arch/arm64/boot/dts/rockchip/rk3568-rock-3b.dts
 index 20d2b5f..06f022f 100644
 --- a/arch/arm64/boot/dts/rockchip/rk3568-rock-3b.dts
 +++ b/arch/arm64/boot/dts/rockchip/rk3568-rock-3b.dts
 @@ -295,6 +295,8 @@
  &gpu {
  	mali-supply = <&vdd_gpu>;
  	status = "okay";
 +	interrupt-names = "gpu", "mmu", "job";
 +	clock-names = "gpu", "bus";
 &hdmi {
  • Execute ./compile.sh BOARD=rock-3a BRANCH=legacy kernel-config and in the configuration menu that shows up, disable(by pressing the n key on your keyboard) the CONFIG_DRM_IGNORE_IOTCL_PERMIT option under Device Drivers->GPU Support->DRM->Ignore iotcl permit and make sure Panfrost is enabled
  • Compile the kernel with the command ./compile.sh BOARD=rock-3a BRANCH=legacy kernel
  • You’ll now find radxa’s rkr 4.1 kernel with panfrost working and all other hardware features working in the folder build/output/debs/linux-image-*.deb
When you boot up with the patched kernel and have mesa 21.2+(with panfrost driver compiled) installed, you’ll find ‘Panfrost’ as the GL rendenrer when you execute the command glxinfo -B
Personally I use radxa’s rkr 4.1 kernel source instead of Armbian since MIPI DSI still doesn’t work on Armbian’s linux-rockchip rkr6 kernel source, but besides panfrost all hardware features work on radxa’s rkr 4.1 kernel source.
Credits: Odroid M1 panfrost fix
TDLR: Fix panfrost by making these changes in the rock-3a/rock-3b device tree source, disabling CONFIG_DRM_IGNORE_IOTCL_PERMIT kernel config and enabling CONFIG_PANFROST kernel config and recompile kernel
Still would like to figure out how to get libmali working on Linux 5.10 radxa’s rkr 4.1 kernel source though. If anyone has a working setup do let me know. Since Panfrost’s vulkan implementation is still WIP(as is its OpenCL support), while libmali already has a working Vulkan driver(along with OpenCL 2.1)
As I understand, libmali requires rockchip’s patched libdrm, libdrm-cursor, xserver, librga-multi in order to achieve DE GPU acceleration? I’m currently using JeffyCN’s libmali repo, if there’s a better/working repo elsewhere, let me know. Preferably with source code so I can compile myself since the prebuilt debs from rockchip only work with Debian Bullseye(I’m on Debian Bookworm)
I see that it’s possible to get libmali working with panfork on the same system for RK3588, is it possible to get libmali working with panfrost on RK3568? Tried that just now, but libmali keeps complaining about the kbase kernel module not being loaded(it is, I checked with lsmod)
How do you test the Vulkan driver?
*Anyway, i have libmali (without panfrost) running on Ubuntu 22.04.3, rkr4.1, Wayland, and not X11.
Just built a rock3a image with armbian legacy kernel(rk-5.10-rkr6), panfrost driver is working well. Rock3b is not supported by armbian’s 5.10 kernel devicetree, but you don’t need to modify armbian’s kernel config because panfrost is enabled by default for mali g52 and arm’s mali DDK kernel driver is disabled. You only need to modify devicetree of rock3b to make it work with panfrost kernel driver.
Oh I ran the command ‘vkcube’ from Debian/Ubuntu package ‘vulkan-tools’, but I haven’t managed to test Vulkan with libmali since I never managed to get it to work lol. Only tested panvk(which can’t run vkcube properly
That’s amazing, may I ask which .deb package you use or what steps did you take to set up all the *.so? I tried building the .deb package from JeffyCN/mirrors and installing the libmali-g52-bifrost-g2p0-x11-gbm.deb but it doesn’t work. glmark2-es2 crashes the whole desktop(XFCE with X11) and even es2_info crashes the whole desktop.
Do I have to install Rockchip’s patched xserver and libdrm to get libmali working?
Thank you! Have managed to get panfrost working :slight_smile: Now left with getting libmali to work
Yes, you need the patched xserver or you get a blank screen and the cursor on the left. I used libdrm from the distro. I did not enable panfrost on the kernel. The instructions are correct, the only difference is i compiled natively.
Oh by this do you mean rockchip’s patched libdrm or the libdrm from Ubuntu’s git? From what I saw on JeffyCN/meta-yocto it seems like there’s a rockchip-libdrm deb package, but I couldn’t find the source code to compile it myself.
No wonder lol, I always got that when I installed the newer libmali g13p0 libraries, I thought that meant that libmali wasn’t working, seems like the opposite, it’s a sign that libmali is working(I just didn’t install patched rockchip xserver)
Thanks for the info!
I mean from Ubuntu.
ii  libdrm-common                          2.4.113-2~ubuntu0.22.04.1                   all          Userspace interface to kernel DRM services -- common files
    ii  libdrm-dev:arm64                       2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to kernel DRM services -- development files
    ii  libdrm-etnaviv1:arm64                  2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to etnaviv-specific kernel DRM services -- runtime
    ii  libdrm-freedreno1:arm64                2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to msm/kgsl kernel DRM services -- runtime
    ii  libdrm-nouveau2:arm64                  2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to nouveau-specific kernel DRM services -- runtime
    ii  libdrm-radeon1:arm64                   2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to radeon-specific kernel DRM services -- runtime
    ii  libdrm-tegra0:arm64                    2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to tegra-specific kernel DRM services -- runtime
    ii  libdrm2:arm64                          2.4.113-2~ubuntu0.22.04.1                   arm64        Userspace interface to kernel DRM services -- runtime
Wow wait how did you get libmali working on Wayland? I finally managed to get libmali working on X11 by installing rockchip’s patched xserver, haven’t tried Wayland yet. Do I simply install the wayland-gbm deb package of libmali and also install xserver like before?
Also, is it normal that glxinfo -B still shows ‘llvmpipe’ as the OpenGL renderer after getting libmali working(es2_info shows Mali G52 as the OpenGL ES renderer)? I’m able to run glxgears with libmali using gl4es, but is there any way to get the desktop accelerated by gl4es by default or is that a bad idea? Just find the desktop kinda laggy compared to Panfrost-accelerated desktop, although when I check Xorg.log I can see that desktop is successfully accelerated by Rockchip’s glamor hacks already.
Thank you for your help!
Update on progress: Managed to compile Mesa 24.1.0 for Debian 12.
Find the set of complete Mesa 24.1.0 Debian packages here. Note that these packages can only be installed on Debian 12(Bookworm). I’ve compiled most of the important drivers(at least for ARM), including the experimental panvk driver and rusticl. However, I couldn’t get rusticl working on my Rock 3B even though panfrost supposedly supports rusticl.
To get OpenGL working, install these debs: libgl1-mesa-dri*.deb libglx-mesa0*.deb libegl1-mesa*.deb libegl-mesa0-*.deb libgles2-mesa*.deb libgbm1*.deb libglapi-mesa*.deb.
Optionally, if you want to test panvk, install the mesa-vulkan-drivers*.deb package as well. To run Vulkan apps with panvk, you need to set the PAN_I_WANT_A_BROKEN_VULKAN_DRIVER environment variable to 1. For example, to run vkcube with panvk, execute this command PAN_I_WANT_A_BROKEN_VULKAN_DRIVER=1 vkcube.
Also optionally, if you want to test rusticl, install the mesa-opencl-icd*.deb package. Then check whether OpenCL is supported on your device by running the clinfo command.
Can you tell me how to compile Mesa 24.1.0 packages on Debian 12 bookworm? Thanks.
Apologies for the delayed response, you need to:
  • First set up a sbuild environment(see Debian’s sbuild wiki).
  • Then you need to compile some of the build dependencies that are missing from Debian’s bookworm distribution but required by newer Mesa, e.g. bindgen and cbindgen(these 2 can be compiled by installing their corresponding rust binaries using cargo, which will compile these 2 binaries from source).
  • Now patch Debian’s Mesa source(for me I just needed to modify the debian/ packaging configs) to lower some of the build dependency requirements(you can refer to my mesa patches for reference):
    • Use LLVM 15, this means changing all of the clang, llvm, libclc, etc dependencies to their version 15 packages
    • Disable amd Vulkan driver and radeonsi Gallium3D driver in debian/rules file
  • Then build your modified source using sbuild, telling sbuild to use your self-compiled build dependencies with the parameter ‘–extra-package’
I don’t have the time to go into detail so you likely have to do a lot more reading on your own to learn the minute details of each step above
