just received my sata hat and top hat. No 10 pin cable included, thank you Grrr
brand new SSD, Brand new SD card, flashed the latest Raspbian Buster. installed sata hat on Raspberry Pi 4B. Using the Pi Foundations power supply for the Pi4. Booted up, configured raspbian, installed the script for the sata hat and rebooted. Boots up, red lights flash across all 4 sata sockets then sata1, with the 64GB SSD has the blue light on. fdisk -l shows it as /dev/sda
partition the disk, write the partition, and get the offset error posted in another thread. ran fdisk again and made the start block 65536. no more error. Write the partition, done
try to run mkfs, and it starts, after about 10 seconds of nothing I get a kernel oops and it never comes back. I can ssh in and see status showing the drive, but fdisk -l shows nothing, There is a kernel crash, and there are a TON of DMA errors…
here is the Terminal output:
root@raspberrypi:/home# mkfs.ext4 /dev/sda1
mke2fs 1.44.5 (15-Dec-2018)
Creating filesystem with 15630336 4k blocks and 3915216 inodes
Filesystem UUID: 2f9b5a62-5ca1-422e-879d-c2449e48b370
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information:
Message from syslogd@raspberrypi at Jan 23 12:50:17 …
kernel:[ 313.131451] Internal error: Oops: 96000146 [#1] PREEMPT SMP
kernel:[ 313.131556] Process scsi_eh_0 (pid: 593, stack limit = 0x00000000253d574b)
kernel:[ 313.131870] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21)
