Raspberry Camera V2 does not work
I am trying to use a Raspberry cam V2 on the CSI port with the RockPi 4 on Debian Buster.
I activated the overlay imx219, but cant get it to work.
using test_camera-rkisp1.sh in console fails (command unknown)
I also cant find the camera using OpenCV.
What am I missing here? The documentation in https://wiki.radxa.com/Rockpi4/hardware/camera/ is unfortunately not very detailed. Please help.
Is there a linux kernel/distrib version/status when the imx/ov camera really worked as radxa wiki says?
Read this post and ask the guy. He got the camera working, does not mention which one but i think the sensor is imx219, and that just needs the libcamera for AWB and 3A for a good image.
If you cannot find test_camera-rkisp1.sh, it is probably not installed. Here at the bottom they give a version with linaro which already includes that script -> https://wiki.radxa.com/Rockpi4/MIPI_Camera
Also, you can run it on a different OS installation, here is the content of test_camera-rkisp1.sh file:
bash$ cat test_camera-rkisp1.sh
#!/bin/sh
export DISPLAY=:0.0
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/aarch64-linux-gnu/gstreamer-1.0
#export GST_DEBUG=ispsrc:5
#export GST_DEBUG_FILE=/tmp/2.txt
echo "Start RKISP Camera Preview!"
su linaro -c " \
	gst-launch-1.0 rkv4l2src device=/dev/video0 ! video/x-raw,format=NV12,width=1920,height=1080, framerate=30/1 ! videoconvert ! autovideosink"
Command gst-launch-1.0 rkv4l2src device=/dev/video0 ! video/x-raw,format=NV12,width=1920,height=1080, framerate=30/1 ! videoconvert ! autovideosink works after installing gstreamer.
I’ve been struggling with it for 1 week, I’ve downloaded all the referenced versions, none of them work.
And from that gstreamer example, only a gray blob comes out.
Look at the forum here, it doesn’t work for anyone. There are several years’ worth of error tickets, and 0 of them have been closed.
Have you tried it? No one has seen it in action yet :smiley:
From official rockchip documentation:
v4l2-ctl -d /dev/video0 --set-fmt-video=width= 1920 ,height= 1080 ,pixelformat=NV12 --stream-mmap= 3 --stream-skip= 3 --stream-to=/tmp/cif.out --stream-count= 1 --stream-poll
and
W= 1920 ; H= 1080 ; mplayer /tmp/cif.out -loop 0 -demuxer rawvideo -fps 25 \-rawvideo w=${W}:h=${H}:size=$((${W}*${H}* 3 / 2 )):format=NV12
Result: Black screen or gray noise.
Or
streamer -o 5 .jpeg -c /dev/video0
Black screen
“Best” result:
gst-launch-1.0 rkv4l2src device=/dev/video0 io-mode=4 isp-mode=2A ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=%d.jpg
Dark green thing, barely recognized pictures.
Have you tried set example exposure?
v4l2-ctl -d /dev/video0 --set-ctrl 'exposure=1216,analogue_gain=10' or video1-2-3
Return error :slight_smile:
But if you think I can continue, I have several hundred pages of logs, commands, kernel versions, distribes and hardware.
/boot/hw_intfc.conf
    intfc:spi1=on
    # Add imx219 camera module support. Need disabled ov5647 camera module.
    intfc:dtoverlay=imx219
dmesg | grep imx
    [    2.599576] imx219 4-0010: GPIO lookup for consumer pwdn
    [    2.599587] imx219 4-0010: using device tree for GPIO lookup
    [    2.649799] imx219 4-0010: Model ID 0x0219, Lot ID 0x1c8b77, Chip ID 0x087c
#!/bin/sh
export DISPLAY=:0.0
su linaro -c " \
kernel module (built-in, lsmod shows):
https://github.com/54shady/qop_kernel/blob/master/drivers/media/i2c/imx219.c
gst-launch:
https://gstreamer.freedesktop.org/documentation/tools/gst-launch.html?gi-language=c
v4l2src
https://people.freedesktop.org/~tsaunier/documentation/video4linux2-1.0/v4l2src.html?gi-language=c
opencv (deps hell)
https://www.geeksforgeeks.org/how-to-capture-a-image-from-webcam-in-python/
Result dark green sh!t, from official rockchip documentation:
Official rockchip documentation:
https://usermanual.wiki/Document/RockchipC2A0Linux20CameraC2A0Developer20Guide20V11.324153775/html
sudo echo 1 > /sys/module/video_rkisp1/parameters/debug
Driver Info (not using libv4l2):
Driver name : rkisp1
Card type : rkisp1_mainpath
Bus info : platform:ff910000.rkisp1
Driver version: 4.4.154
Capabilities : 0x84201000
Video Capture Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
root@linaro-alip:/home/linaro# media-ctl --known-mbus-fmts
RGB444_1X12 0x1016
RGB444_2X8_PADHI_BE 0x1001
RGB444_2X8_PADHI_LE 0x1002
RGB555_2X8_PADHI_BE 0x1003
RGB555_2X8_PADHI_LE 0x1004
RGB565_1X16 0x1017
BGR565_2X8_BE 0x1005
BGR565_2X8_LE 0x1006
RGB565_2X8_BE 0x1007
RGB565_2X8_LE 0x1008
RGB666_1X18 0x1009
RBG888_1X24 0x100e
RGB666_1X24_CPADHI 0x1015
RGB666_1X7X3_SPWG 0x1010
BGR888_1X24 0x1013
GBR888_1X24 0x1014
RGB888_1X24 0x100a
RGB888_2X12_BE 0x100b
RGB888_2X12_LE 0x100c
RGB888_1X7X4_SPWG 0x1011
RGB888_1X7X4_JEIDA 0x1012
ARGB8888_1X32 0x100d
RGB888_1X32_PADHI 0x100f
Y8_1X8 0x2001
UV8_1X8 0x2015
UYVY8_1_5X8 0x2002
VYUY8_1_5X8 0x2003
YUYV8_1_5X8 0x2004
YVYU8_1_5X8 0x2005
UYVY8_2X8 0x2006
VYUY8_2X8 0x2007
YUYV8_2X8 0x2008
YVYU8_2X8 0x2009
Y10_1X10 0x200a
UYVY10_2X10 0x2018
VYUY10_2X10 0x2019
YUYV10_2X10 0x200b
YVYU10_2X10 0x200c
Y12_1X12 0x2013
UYVY12_2X12 0x201c
VYUY12_2X12 0x201d
YUYV12_2X12 0x201e
YVYU12_2X12 0x201f
UYVY8_1X16 0x200f
VYUY8_1X16 0x2010
YUYV8_1X16 0x2011
YVYU8_1X16 0x2012
YDYUYDYV8_1X16 0x2014
UYVY10_1X20 0x201a
VYUY10_1X20 0x201b
YUYV10_1X20 0x200d
YVYU10_1X20 0x200e
VUY8_1X24 0x2024
YUV8_1X24 0x2025
UYVY12_1X24 0x2020
VYUY12_1X24 0x2021
YUYV12_1X24 0x2022
YVYU12_1X24 0x2023
YUV10_1X30 0x2016
AYUV8_1X32 0x2017
SBGGR8_1X8 0x3001
SGBRG8_1X8 0x3013
SGRBG8_1X8 0x3002
SRGGB8_1X8 0x3014
SBGGR10_ALAW8_1X8 0x3015
SGBRG10_ALAW8_1X8 0x3016
SGRBG10_ALAW8_1X8 0x3017
SRGGB10_ALAW8_1X8 0x3018
SBGGR10_DPCM8_1X8 0x300b
SGBRG10_DPCM8_1X8 0x300c
SGRBG10_DPCM8_1X8 0x3009
SRGGB10_DPCM8_1X8 0x300d
SBGGR10_2X8_PADHI_BE 0x3003
SBGGR10_2X8_PADHI_LE 0x3004
SBGGR10_2X8_PADLO_BE 0x3005
SBGGR10_2X8_PADLO_LE 0x3006
SBGGR10_1X10 0x3007
SGBRG10_1X10 0x300e
SGRBG10_1X10 0x300a
SRGGB10_1X10 0x300f
SBGGR12_1X12 0x3008
SGBRG12_1X12 0x3010
SGRBG12_1X12 0x3011
SRGGB12_1X12 0x3012
SBGGR14_1X14 0x3019
SGBRG14_1X14 0x301a
SGRBG14_1X14 0x301b
SRGGB14_1X14 0x301c
SBGGR16_1X16 0x301d
SGBRG16_1X16 0x301e
SGRBG16_1X16 0x301f
SRGGB16_1X16 0x3020
JPEG_1X8 0x4001
S5C_UYVY_JPEG_1X8 0x5001
AHSV8888_1X32 0x6001
root@linaro-alip:/home/linaro# media-ctl -d /dev/media0 -p
Media controller API version 0.1.0
Media device information
driver rkisp1
model rkisp1
serial
bus info
hw revision 0x0
driver version 0.0.0
Device topology
- entity 1: rkisp1-isp-subdev (4 pads, 5 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:SBGGR10_1X10/800x600 field:none
crop.bounds:(0,0)/800x600
crop:(0,0)/800x600]
<- "rockchip-sy-mipi-dphy":1 [ENABLED]
pad1: Sink
<- "rkisp1-input-params":0 [ENABLED]
pad2: Source
[fmt:YUYV8_2X8/800x600 field:none
crop:(0,0)/800x600]
-> "rkisp1_selfpath":0 [ENABLED]
-> "rkisp1_mainpath":0 [ENABLED]
pad3: Source
-> "rkisp1-statistics":0 [ENABLED]
- entity 2: rkisp1_mainpath (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rkisp1-isp-subdev":2 [ENABLED]
- entity 3: rkisp1_selfpath (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
- entity 4: rkisp1-statistics (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "rkisp1-isp-subdev":3 [ENABLED]
- entity 5: rkisp1-input-params (1 pad, 1 link)
device node name /dev/video3
pad0: Source
-> "rkisp1-isp-subdev":1 [ENABLED]
- entity 6: rockchip-sy-mipi-dphy (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:SRGGB10_1X10/1920x1080 field:none]
<- "imx219 4-0010":0 [ENABLED]
pad1: Source
-> "rkisp1-isp-subdev":0 [ENABLED]
- entity 7: imx219 4-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
-> "rockchip-sy-mipi-dphy":0 [ENABLED]
linaro@linaro-alip:~$ gst-inspect-1.0 rkv4l2src
Factory Details:
Rank primary (256)
Long-name Rockchip Video (video4linux2) Source
Klass Source/Video
Description Reads frames from a Rockchip Video4Linux2 device
Author Leo Wen <[email protected]>
Plugin Details:
Name rkv4l2
Description Rockchip elements for Video 4 Linux
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstrkv4l2.so
Version 1.10.4
License LGPL
Source module gst-plugins-good
Source release date 2017-02-23
Binary package GStreamer Good Plug-ins source release
Origin URL Unknown package origin
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstPushSrc
+----GstRKV4l2Src
Implemented Interfaces:
GstURIHandler
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
image/jpeg
video/mpeg
mpegversion: 4
systemstream: false
video/mpeg
mpegversion: 2
video/mpegts
systemstream: true
video/x-bayer
format: { bggr, gbrg, grbg, rggb }
width: [ 1, 32768 ]
height: [ 1, 32768 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-dv
systemstream: true
video/x-h263
variant: itu
video/x-h264
stream-format: { byte-stream, avc }
alignment: au
video/x-pwc1
width: [ 1, 32768 ]
video/x-pwc2
width: [ 1, 32768 ]
video/x-raw
format: { RGB16, BGR, RGB, GRAY8, GRAY16_LE, GRAY16_BE, YVU9, YV12, YUY2, YVYU, UYVY, Y42B, Y41B, YUV9, NV12_64Z32, NV24, NV61, NV16, NV21, NV12, I420, BGRA, BGRx, ARGB, xRGB, BGR15, RGB15 }
width: [ 1, 32768 ]
video/x-sonix
width: [ 1, 32768 ]
video/x-vp8
video/x-vp9
video/x-wmv
wmvversion: 3
format: WVC1
Element Flags:
no flags set
Element Implementation:
Has change_state() function: 0x7f8cf4d980
Element has no clocking capabilities.
URI handling capabilities:
Element can act as source.
Supported URI protocols:
v4l2
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "rkv4l2src0"
parent : The parent of the object
Object of type "GstObject"
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
typefind : Run typefind before negotiating
Boolean. Default: false
do-timestamp : Apply current stream time to buffers
device : Device location
String. Default: "/dev/video0"
device-name : Name of the device
flags: readable
String. Default: null
device-fd : File descriptor of the device
flags: readable
flags : Device type flags
flags: readable
Flags "GstRKV4l2DeviceTypeFlags" Default: 0x00000000, "(none)"
(0x00000001): capture - Device supports video capture
(0x00000002): output - Device supports video playback
(0x00000004): overlay - Device supports video overlay
(0x00000010): vbi-capture - Device supports the VBI capture
(0x00000020): vbi-output - Device supports the VBI output
(0x00020000): audio - Device has audio inputs or outputs
brightness : Picture brightness, or more precisely, the black level
flags: readable, writable, controllable
Integer. Range: -2147483648 - 2147483647 Default: 0
contrast : Picture contrast or luma gain
saturation : Picture color saturation or chroma gain
hue : Hue or color balance
io-mode : I/O mode
Enum "GstRKV4l2IOMode" Default: 0, "auto"
(0): auto - GST_V4L2_IO_AUTO
(1): rw - GST_V4L2_IO_RW
(2): mmap - GST_V4L2_IO_MMAP
(3): userptr - GST_V4L2_IO_USERPTR
(4): dmabuf - GST_V4L2_IO_DMABUF
(5): dmabuf-import - GST_V4L2_IO_DMABUF_IMPORT
extra-controls : Extra v4l2 controls (CIDs) for the device
Boxed pointer of type "GstStructure"
pixel-aspect-ratio : Overwrite the pixel aspect ratio of the device
force-aspect-ratio : When enabled, the pixel aspect ratio will be enforced
Boolean. Default: true
isp-mode :
Enum "GstRk3AMode" Default: 0, "0A"
(0): 0A - RK_3A_DISABLE
(1): 2A - RK_3A_AEAWB
(2): 3A - RK_3A_AEAWBAF
xml-path :
String. Default: "/etc/cam_iq.xml"
Element Signals:
"prepare-format" : void user_function (GstElement* object,
gint arg0,
GstCaps* arg1,
gpointer user_data);
v4l2-ctl -d /dev/video0 -l
User Controls
                       exposure (int)    : min=0 max=4095 step=1 default=1575 value=1575
                           gain (int)    : min=256 max=43663 step=1 default=256 value=256
                horizontal_flip (bool)   : default=0 value=0
                  vertical_flip (bool)   : default=0 value=0
Image Source Controls
              vertical_blanking (int)    : min=686 max=686 step=1 default=686 value=686
            horizontal_blanking (int)    : min=1524 max=1524 step=1 default=1524 value=1524
                  analogue_gain (int)    : min=256 max=2816 step=1 default=512 value=512
Image Processing Controls
                 link_frequency (intmenu): min=0 max=0 default=0 value=0
                     pixel_rate (int64)  : min=0 max=182463120 step=1 default=182463120 value=182463120 flags=read-only
                   test_pattern (menu)   : min=0 max=13 default=0 value=0
v4l2-ctl --list-formats-ext --device /dev/video0
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture Multiplanar
        Pixel Format: 'YUYV'
        Index       : 1
        Pixel Format: 'YVYU'
        Index       : 2
        Pixel Format: 'VYUY'
        Index       : 3
        Pixel Format: '422P'
        Name        : Planar YVU 4:2:2
        Index       : 4
        Pixel Format: 'NV16'
        Index       : 5
        Pixel Format: 'NV61'
        Index       : 6
        Pixel Format: 'YM61'
        Name        : Planar YVU 4:2:2 (N-C)
        Index       : 7
        Pixel Format: 'NV21'
        Index       : 8
        Pixel Format: 'NV12'
        Index       : 9
        Pixel Format: 'NM21'
        Name        : Y/CrCb 4:2:0 (N-C)
        Index       : 10
        Pixel Format: 'NM12'
        Name        : Y/CbCr 4:2:0 (N-C)
        Index       : 11
        Pixel Format: 'YU12'
        Name        : Planar YUV 4:2:0
        Index       : 12
        Pixel Format: 'YV12'
        Name        : Planar YVU 4:2:0
        Index       : 13
        Pixel Format: 'YM24'
        Name        : Planar YUV 4:4:4 (N-C)
        Index       : 14
        Pixel Format: 'GREY'
        Name        : 8-bit Greyscale
        Index       : 15
        Pixel Format: 'RGGB'
        Name        : 8-bit Bayer RGRG/GBGB
        Index       : 16
        Pixel Format: 'GRBG'
        Name        : 8-bit Bayer GRGR/BGBG
        Index       : 17
        Pixel Format: 'GBRG'
        Name        : 8-bit Bayer GBGB/RGRG
        Index       : 18
        Pixel Format: 'BA81'
        Name        : 8-bit Bayer BGBG/GRGR
        Index       : 19
        Index       : 20
        Pixel Format: 'BA10'
        Name        : 10-bit Bayer GRGR/BGBG
        Index       : 21
        Pixel Format: 'GB10'
        Name        : 10-bit Bayer GBGB/RGRG
        Index       : 22
        Pixel Format: 'BG10'
        Name        : 10-bit Bayer BGBG/GRGR
        Index       : 23
        Pixel Format: 'RG12'
        Name        : 12-bit Bayer RGRG/GBGB
        Index       : 24
        Pixel Format: 'BA12'
        Name        : 12-bit Bayer GRGR/BGBG
        Index       : 25
        Pixel Format: 'GB12'
        Name        : 12-bit Bayer GBGB/RGRG
        Index       : 26
        Pixel Format: 'BG12'
        Name        : 12-bit Bayer BGBG/GRGR
linaro@linaro-alip:~$ v4l2-compliance
v4l2-compliance SHA   : not available
Driver Info:
                Streaming
                Extended Pix Format
                Device Capabilities
                Streaming
                Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
        test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
        test second video open: OK
        test VIDIOC_G/S_PRIORITY: OK
        test for unlimited opens: OK
Debug ioctls:
        test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
        test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
        test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
        test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
        test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
        test VIDIOC_ENUMAUDIO: OK (Not Supported)
                fail: v4l2-test-input-output.cpp(420): G_INPUT not supported for a capture device
        test VIDIOC_G/S/ENUMINPUT: FAIL
        test VIDIOC_G/S_AUDIO: OK (Not Supported)
        Inputs: 0 Audio Inputs: 0 Tuners: 0
Output ioctls:
        test VIDIOC_G/S_MODULATOR: OK (Not Supported)
        test VIDIOC_ENUMAUDOUT: OK (Not Supported)
        test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
        test VIDIOC_G/S_AUDOUT: OK (Not Supported)
        Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
        test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
        test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
        test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
        test VIDIOC_G/S_EDID: OK (Not Supported)
        Control ioctls:
                test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
                test VIDIOC_QUERYCTRL: OK
                test VIDIOC_G/S_CTRL: OK
                fail: v4l2-test-controls.cpp(723): could not get all controls
                test VIDIOC_G/S/TRY_EXT_CTRLS: FAIL
                fail: v4l2-test-controls.cpp(782): subscribe event for control 'User Controls' failed
                test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: FAIL
                test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
                Standard Controls: 13 Private Controls: 0
        Format ioctls:
                fail: v4l2-test-formats.cpp(272): duplicate format 42474752 (RGGB)
                test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
                test VIDIOC_G/S_PARM: OK (Not Supported)
                test VIDIOC_G_FBUF: OK (Not Supported)
                fail: v4l2-test-formats.cpp(328): !colorspace
                fail: v4l2-test-formats.cpp(451): testColorspace(pix_mp.pixelformat, pix_mp.colorspace, pix_mp.ycbcr_enc, pix_mp.quantization)
                test VIDIOC_G_FMT: FAIL
                test VIDIOC_TRY_FMT: OK (Not Supported)
                test VIDIOC_S_FMT: OK (Not Supported)
                test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
                fail: v4l2-test-formats.cpp(1273): doioctl(node, VIDIOC_G_SELECTION, &sel) != EINVAL
                test Cropping: FAIL
                test Composing: OK (Not Supported)
                test Scaling: OK
        Codec ioctls:
                test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
                test VIDIOC_G_ENC_INDEX: OK (Not Supported)
                test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
        Buffer ioctls:
                test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
                fail: v4l2-test-buffers.cpp(571): q.has_expbuf(node)
                test VIDIOC_EXPBUF: FAIL
Test input 0:
Total: 43, Succeeded: 36, Failed: 7, Warnings: 0
imx219
Chroma      = Color, RGB
Data Format = Raw Bayer 10bit
https://www.arducam.com/downloads/modules/RaspberryPi_camera/IMX219DS.PDF
Full raspberry camera documentations https://www.raspberrypi.com/documentation/accessories/camera.html
When I first tried it, it was a sunny day and I was outside, and thought the camera worked because I could see the objects but they were white/greenish. With low light, nothing can be seen, I think the problem is something to do with the camera drivers
Hehehe, jeah “working” he got this nice pic:
Hahaha I meant I could take a picture(sorry if misunderstood), I’ve been still struggling to solve this lighting thing :confused:
Btw I have the exact configuration you mentioned..
I think the camera is working. What you see is a ‘raw’ image from the sensor, which needs to adjust exposure and gain. This is done by libcamera or rockchip camera engine. Someone pointed out where rockchip prebuilt deb packages are in github. Try to install it, if there is an iqfile for your sensor, it will auto adjust when you grab the frame. You can also try collabora kernel which has support for imx219 and rockpi 4, also, see if this can help: https://lists.libcamera.org/pipermail/libcamera-devel/2020-February/006771.html
