I have a Radxa Zero V1.5 board with 512Mb ram and no eMMC.
I tried about 6 or 7 Armbian Bullseye and buster images from Radxa repository and also armbian Jammy and same problem.
I have tried multiple known working SD cards and the same problem.
It seems to get to U-boot and then just restarts in endless loop.
The log file for those will be 1st.
I also read this post:
https://forum.radxa.com/t/radxa-zero-model-ram-512m-not-boot/7348
I tried the image linked in that post and it didnt work, either.
Armbian_21.08.0-trunk_Radxa-zero_focal_current_5.10.58_xfce_desktop.img.xz
I will post the log from that also:
Any help would be appreciated.
Here is Serial log 1:
from using current builds.
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0
l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02no sdio debug board detected
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180TE: 378506
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
Load FIP HDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from SD, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from SD, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
fastboot data verify
verify result: 266
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from SD, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from SD, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
INFO : Training has run successfully!channel==0
RxClkDly_Margin_A0==256 ps 13
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==0 ps 0
TxDqDly_Margin_A1==0 ps 0
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==32
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==0
DeviceVref_Margin_A1==0channel==1
RxClkDly_Margin_A0==236 ps 12
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==30
DeviceVref_Margin_A1==0dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004
soc_vref_reg_value 0x 0000001a 0000001c 0000001d 0000001c 0000001b 0000001b 0000001a 0000001d 0000001a 0000001c 0000001b 0000001a 0000001b 0000001c 0000001c 0000001d 00000019 00000018 00000018 0000001b 00000019 00000019 00000017 0000001a 00000017 0000001a 0000001a 0000001a 00000019 00000019 00000017 00000019 dram_vref_reg_value 0x 00000057
2D training succeed
auto size-- 65535DDR cs0 size: 512MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002aDDR size: 512MB
cs0 DataBus test pass
cs0 AddrBus test pass100bdlr_step_size ps== 474
result report
Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from SD, src: 0x0006c200, des: 0x0175c000, size: 0x00094000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 04 18 00 00 19 35 36 32 43 46 50
[0.017150 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fc40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BL31: G12A normal boot!
NOTICE: BL31: BL33 decompress pass
ERROR: Error initializing runtime service opteed_fastU-Boot 2021.07-armbian (Nov 14 2021 - 14:28:29 +0000) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM: 512 MiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
7895 bytes read in 3 ms (2.5 MiB/s)Executing script at 08000000
U-boot default fdtfile: amlogic/meson-g12a-radxa-zero.dtb
Current variant:
** Reading file would overwrite reserved memory **
Failed to load ‘/boot/armbianEnv.txt’
“Synchronous Abort” handler, esr 0x96000010
elr: 000000000105f0b0 lr : 000000000105d284 (reloc)
elr: 000000001dfb30b0 lr : 000000001dfb1284
x0 : 000000001bf74470 x1 : 0000000032000000
x2 : 0000000000001ed7 x3 : 0000000000000000
x4 : 0000000000001ed7 x5 : 0000000000000000
x6 : 0000000000000682 x7 : 0000000000000000
x8 : 0000000000000010 x9 : 0000000000000008
x10: 0000000000000044 x11: 000000001bf3e23c
x12: 0000000000000670 x13: 000000001bf3e25c
x14: 0000000000000000 x15: 000000001bf405b0
x16: 000000001df63690 x17: 0000000000000000
x18: 000000001bf51dd0 x19: 0000000000000000
x20: 0000000032000000 x21: 000000001bf74470
x22: 0000000000000000 x23: 000000001dfd8a70
x24: 0000000000000000 x25: 0000000000000001
x26: 000000000000000a x27: 0000000000000000
x28: 0000000000001ed7 x29: 000000001bf3e350Code: d2800003 eb03005f 540001c1 d65f03c0 (f8636824)
Resetting CPU …resetting …
bl31 reboot reason: 0xd
bl31 reboot reason: 0x0
system cmd 1.
Here is Serial log 2:
using the image linked on this post:
Radxa zero model RAM 512M not boot
l2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 375170
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
fw parse done
PIEI prepare done
fastboot data load
verify result: 266
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
Check phy result
1D training succeed
Check phy result
channel==0
TrainedVREFDQ_A1==0
channel==1
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==31
soc_vref_reg_value 0x 0000001a 0000001b 0000001d 0000001b 0000001b 0000001b 0000001a 0000001d 00000019 0000001c 0000001a 0000001a 0000001a 0000001c 0000001c 0000001d 0000001a 00000019 00000019 0000001b 0000001a 0000001b 00000018 0000001a 00000017 0000001b 0000001b 0000001b 00000019 0000001a 00000019 00000019 dram_vref_reg_value 0x 00000059
2D training succeed
DDR cs1 size: 0MB
100bdlr_step_size ps== 489
result report
Load BL3X from SD, src: 0x0006c200, des: 0x0175c000, size: 0x000a0000, part: 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
secure task start!
high task start!
low task start!
run into bl31
U-Boot 2021.04-armbian (Aug 13 2021 - 07:09:10 +0000) radxazero
Model: Radxa Zero
SoC: Amlogic Meson G12A (Unknown) Revision 28:c (30:2)
DRAM: 512 MiB
Loading Environment from MMC… Card did not respond to voltage select! : -110
*** Warning - No block device, using default environment
In: serial@3000
Out: serial@3000
Err: serial@3000
No ethernet found.
Error: “load_logo” not defined
Scanning mmc 1:1…
7622 bytes read in 3 ms (2.4 MiB/s)
Current variant:
elr: 000000000106b62c lr : 000000000106980c (reloc)
elr: 000000001dfab62c lr : 000000001dfa980c
x0 : 000000001bf54eb0 x1 : 0000000032000000
x2 : 0000000000001dc6 x3 : 0000000000000000
x4 : 0000000000001dc6 x5 : 0000000000000000
x10: 0000000000000044 x11: 000000001bf1bcbc
x12: 0000000000000684 x13: 000000001bf1bcdc
x14: 0000000000000000 x15: 000000001bf1e050
x16: 000000001df51268 x17: 0000000000000000
x18: 000000001bf2fdd0 x19: 0000000000000000
x20: 0000000032000000 x21: 000000001bf54eb0
x22: 0000000000000000 x23: 000000001dfd75b8
x28: 0000000000001dc6 x29: 000000001bf1bdf0
Resetting CPU …
resetting …
Rebooting with reason: 0x1
bl31 reboot reason: 0x1
system cmd 1.
