Radxa zero model RAM 512M not boot from sdcard
but model 4/32G work perfact
OS TwisterOS beta4
What Os are your trying to boot? TwisterOS beta4 may be too āheavyā for 512Mb of RAM only.
Anyway, you need to flash u-boot.bin.sd.bin to uSD(microSD) card to be able to boot from uSD on 512Mb Zero.
Instructions for TwisterOS Beta4:
Download the TwisterOS beta4 image and extract it.
https://drive.google.com/file/d/1aqB7A_EuLGvL7pR8LhP6RatikxvJyy6i/view?usp=sharing -
Download u-boot from dl.radxa.com:
https://dl.radxa.com/zero/images/loader/u-boot.bin.sd.bin -
Copy Twister image to SD card via dd or use Etcher to flash to uSD:
dd if=TwisterOS.Armbian.Focal.Radxa-Zero.Beta4.img of=/dev/sdb bs=1M status=progress
- After this is finished , copy the downloaded u-boot.bin.sd.bin to the SD card (in two steps):
dd if=u-boot.bin.sd.bin of=/dev/sdh conv=fsync,notrunc bs=1 count=444
dd if=u-boot.bin.sd.bin of=/dev/sdh conv=fsync,notrunc bs=512 skip=1 seek=1
You can use this system image, https://dl.radxa.com/zero/images/armbian/Armbian_21.08.0-trunk_Radxa-zero_focal_current_5.10.58_xfce_desktop.img.xz, released on September 18th.
Or get files boot.scr and boot.cmd and then put them in /boot directory.
thank you it work
USB-C 3.0 Hub donāt work
How about reverse plug?
stun after update
USB XHCI 1.10
scanning bus usb@ff500000 for devices⦠1 USB Device(s) found
scanning usb for storage devices⦠0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-radxa-zero
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
For 512MB zero, just download the image here, write to sd card. It should boot from sd card.
Doesnāt boot for me?
SD:400;USB:8;LOOP:1;EMMC:800;NAND:81;SD?:0;SD:400;USB:8;LOOP:2;EMMC:800;NAND:81;SD?:0;SD:400;USB:8;
yes it work for 512M model
but after apt-update and apt-upgrade canāt boot again
solution fix before apt-update and apt-upgrade by armbian-config -> freeze kernel
The Armbian upstream doesnāt support 512M amlogic devices. If you want to update the kernel, after the upgrade, download and copy the fix boot.cmd and boot.scr to /boot and reboot for the new kernel.
thank for reply but donāt work
after upgrade and copy boot.cmd and boot.scr canāt boot complete
In: serial@3000
Out: serial@3000
Err: serial@3000
Net: Net Initialization Skipped
No ethernet found.
Error: āload_logoā not defined
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1ā¦
7938 bytes read in 2 ms (3.8 MiB/s)
Executing script at 08000000
U-boot default fdtfile: amlogic/meson-g12a-radxa-zero.dtb
Current variant:
175 bytes read in 2 ms (85 KiB/s)
Current fdtfile after armbianEnv: amlogic/meson-g12a-radxa-zero.dtb
Mainline bootargs: root=UUID=27a3e17f-e2ee-47f0-815b-7ce1c5a24042 rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=d1f9f94d-01 libata.force=noncq usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory swapaccount=1
15827413 bytes read in 708 ms (21.3 MiB/s)
25461248 bytes read in 1115 ms (21.8 MiB/s)
Failed to load ā/boot/dtb/amlogic/meson-g12a-radxa-zero.dtbā
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr " command.
Aborting!
232 bytes read in 5 ms (44.9 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
Executing script at 01600000
Moving Image from 0x8080000 to 0x8200000, end=9ae0000
Loading init Ramdisk from Legacy Image at 13000000 ā¦
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 15827349 Bytes = 15.1 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ⦠OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuingā¦
Scanning disk [email protected]ā¦
Disk [email protected] not ready
Found 2 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
starting USBā¦
Starting the controller
USB XHCI 1.10
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
I have a 2G Radxa Zero with the same problem. I tried to copy boot.cmd and boot.scr but it didnāt work either.
For now, Iām preventing the system from updating the system packages with armbian-config like @winit_a and the armbian tweet said.
Once I could boot the Ubuntu Focal image copying boot.cmd and boot.scr after upgrade. However , this method did not work now.
I looked into the log through tty0 and I knew ā/boot/dtb/amlogic/meson-g12a-radxa-zero.dtbā was missing.
So my current resolution is to back up ā/boot/dtb/amlogic/meson-g12a-radxa-zero.dtbā file before upgrade and restore it after upgrade, then reboot.
thank you it work
wifi lost after upgrade
Me too, one is solved, next appears.
It seems to be long trip for Armbian focal.
I just bought a Radxa zero model RAM 512M in Feb 2024. I tried installng some official OS and failed to boot any of them. Found this topic, after reading the thread, I am shocked!
