Hi
I have just received delivery of a couple Zero 3W’s which I believe have the most recent version of the Wi-Fi/BT chip (Wi-Fi 6).
I have downloaded and installed the latest available version of the OS for use on this board and Wi-Fi chip.
OS Version – radxa-zero3_debian_bullseye_xfce_b6.img
Build - Linux radxa-zero3 5.10.160-26-rk356x
Everything seems to work well with the exception of the GPIO pins.
From a fresh install and after doing the following as per the instructions MRAA installs but has no access to the GPIO pins.
sudo apt-get update
sudo apt-get install libmraa2 libmraa-dev libmraa-java python3-mraa mraa-tools
sudo mraa-gpio version returns “Version v2.2.0 on Unknown platform”
sudo mraa-gpio list returns “No Pins”
Doing the exact same procedure on a Radxa 4C+ works as expected (also on Bullseye and MRAA v2.2.0).
I have also tried OS version – radxa-zero3_debian_bullseye_xfce_b4.img but this gives the same results.
Is there an issue with the OS or is it MRAA as it doesn’t even recognise the platform?
I would greatly appreciate some advice to help me resolve this problem?
Kind regards
Bob
