I’ve been trying to build a NAS with a Raspberry Pi 5 and a Radxa Penta Sata Hat using OMV and LUKS. The disks are 4 x WD Red SA500 1TB in RAID5 format, but I keep getting the errors below. Would anybody have some ideas as to what could be causing the errors ?
SYSLOG
2024-11-30T08:00:01+0000 piNAS CRON[2027262]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
2024-11-30T08:00:01+0000 piNAS CRON[2027263]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
2024-11-30T08:00:03+0000 piNAS CRON[2027262]: pam_unix(cron:session): session closed for user root
2024-11-30T08:05:01+0000 piNAS CRON[2028746]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
2024-11-30T08:05:01+0000 piNAS CRON[2028747]: (root) CMD ( run-parts /var/lib/openmediavault/borgbackup/hourly.d/)
2024-11-30T08:05:01+0000 piNAS CRON[2028746]: pam_unix(cron:session): session closed for user root
2024-11-30T08:09:01+0000 piNAS CRON[2029137]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
2024-11-30T08:09:01+0000 piNAS CRON[2029138]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
2024-11-30T08:09:01+0000 piNAS CRON[2029137]: pam_unix(cron:session): session closed for user root
2024-11-30T08:09:04+0000 piNAS systemd[1]: Starting phpsessionclean.service - Clean php session files…
2024-11-30T08:09:04+0000 piNAS systemd[1]: phpsessionclean.service: Deactivated successfully.
2024-11-30T08:09:04+0000 piNAS systemd[1]: Finished phpsessionclean.service - Clean php session files.
2024-11-30T08:09:17+0000 piNAS openmediavault-webgui[2029213]: Authorized login from xxx.xxx.xxx.xxx [username=admin, user-agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0]
2024-11-30T08:09:50+0000 piNAS kernel: ata3.00: exception Emask 0x52 SAct 0x80000000 SErr 0xffffffff action 0xe frozen
2024-11-30T08:09:50+0000 piNAS kernel: ata3: SError: { RecovData RecovComm UnrecovData Persist Proto HostInt PHYRdyChg PHYInt CommWake 10B8B Dispar BadCRC Handshk LinkSeq TrStaTrns UnrecFIS DevExch }
2024-11-30T08:09:50+0000 piNAS kernel: ata3.00: failed command: READ FPDMA QUEUED
2024-11-30T08:09:50+0000 piNAS kernel: ata3.00: cmd 60/20:f8:80:6b:70/00:00:74:00:00/40 tag 31 ncq dma 16384 in
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x56 (ATA bus error)
2024-11-30T08:09:50+0000 piNAS kernel: ata3.00: status: { DRDY }
2024-11-30T08:09:50+0000 piNAS kernel: ata3: hard resetting link
2024-11-30T08:09:50+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:09:51+0000 piNAS kernel: ata3: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:09:51+0000 piNAS kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:09:56+0000 piNAS kernel: ata3: hard resetting link
2024-11-30T08:09:56+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:09:57+0000 piNAS kernel: ata3: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:09:57+0000 piNAS kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:09:57+0000 piNAS kernel: ata3: limiting SATA link speed to
2024-11-30T08:10:02+0000 piNAS kernel: ata3: hard resetting link
2024-11-30T08:10:02+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:03+0000 piNAS kernel: ata3: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:03+0000 piNAS kernel: ata3: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:03+0000 piNAS kernel: ata3.00: disable device
2024-11-30T08:10:03+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:03+0000 piNAS kernel: sd 2:0:0:0: [sdc] tag#31 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=DRIVER_OK cmd_age=44s
2024-11-30T08:10:03+0000 piNAS kernel: sd 2:0:0:0: [sdc] tag#31 CDB: opcode=0x28 28 00 74 70 6b 80 00 00 20 00
2024-11-30T08:10:03+0000 piNAS kernel: I/O error, dev sdc, sector 1953524608 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
2024-11-30T08:10:03+0000 piNAS kernel: ata3: EH complete
2024-11-30T08:10:03+0000 piNAS kernel: sd 2:0:0:0: rejecting I/O to offline device
2024-11-30T08:10:03+0000 piNAS kernel: ata3.00: detaching (SCSI 2:0:0:0)
2024-11-30T08:10:03+0000 piNAS kernel: device offline error, dev sdc, sector 1953524608 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:03+0000 piNAS kernel: device offline error, dev sdc, sector 1953524616 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:03+0000 piNAS kernel: device offline error, dev sdc, sector 1953524624 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:03+0000 piNAS kernel: device offline error, dev sdc, sector 1953524632 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:03+0000 piNAS omv-engined[2029298]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdc’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdc: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:03+0000 piNAS omv-engined[2029298]: Executing background process failed: Device ‘/dev/sdc’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:03+0000 piNAS omv-engined[2029321]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdc’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdc: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:03+0000 piNAS omv-engined[2029321]: Executing background process failed: Device ‘/dev/sdc’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:03+0000 piNAS kernel: sd 2:0:0:0: [sdc] Synchronizing SCSI cache
2024-11-30T08:10:03+0000 piNAS kernel: sd 2:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x04 driverbyte=DRIVER_OK
2024-11-30T08:10:08+0000 piNAS kernel: md/raid:md0: Disk failure on sdc, disabling device.
2024-11-30T08:10:08+0000 piNAS kernel: md/raid:md0: Operation continuing on 3 devices.
2024-11-30T08:10:19+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:20+0000 piNAS kernel: ata2: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:20+0000 piNAS kernel: ata2: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:25+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:25+0000 piNAS kernel: ata1: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:25+0000 piNAS kernel: ata1: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:30+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:30+0000 piNAS kernel: ata4: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:30+0000 piNAS kernel: ata4: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:35+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:36+0000 piNAS kernel: ata1: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:36+0000 piNAS kernel: ata1: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:36+0000 piNAS kernel: ata1: limiting SATA link speed to
2024-11-30T08:10:41+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:41+0000 piNAS kernel: ata2: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:41+0000 piNAS kernel: ata2: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:41+0000 piNAS kernel: ata2: limiting SATA link speed to
2024-11-30T08:10:47+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:47+0000 piNAS kernel: ata4: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:47+0000 piNAS kernel: ata4: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:47+0000 piNAS kernel: ata4: limiting SATA link speed to
2024-11-30T08:10:52+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:53+0000 piNAS kernel: ata2: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: ata2: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: ata2.00: disable device
2024-11-30T08:10:53+0000 piNAS kernel: ahci 0000:01:00.0: AHCI controller unavailable!
2024-11-30T08:10:53+0000 piNAS kernel: ata1: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: ata1: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: ata1.00: disable device
2024-11-30T08:10:53+0000 piNAS kernel: sd 1:0:0:0: rejecting I/O to offline device
2024-11-30T08:10:53+0000 piNAS kernel: ata4: failed to resume link (SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: I/O error, dev sdb, sector 1953524608 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524608 on sdb).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524616 on sdb).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524624 on sdb).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524632 on sdb).
2024-11-30T08:10:53+0000 piNAS kernel: sd 0:0:0:0: rejecting I/O to offline device
2024-11-30T08:10:53+0000 piNAS kernel: I/O error, dev sda, sector 1953524608 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: ata2.00: detaching (SCSI 1:0:0:0)
2024-11-30T08:10:53+0000 piNAS kernel: I/O error, dev sda, sector 8 op 0x0:(READ) flags 0x800 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: ata1.00: detaching (SCSI 0:0:0:0)
2024-11-30T08:10:53+0000 piNAS kernel: ata4: SATA link down (SStatus FFFFFFFF SControl FFFFFFFF)
2024-11-30T08:10:53+0000 piNAS kernel: ata4.00: disable device
2024-11-30T08:10:53+0000 piNAS kernel: sd 3:0:0:0: rejecting I/O to offline device
2024-11-30T08:10:53+0000 piNAS kernel: I/O error, dev sdd, sector 1953524608 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524608 on sdd).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524616 on sdd).
2024-11-30T08:10:53+0000 piNAS kernel: ata4.00: detaching (SCSI 3:0:0:0)
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sda, sector 1953524608 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sda, sector 1953524616 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sda, sector 1953524624 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sda, sector 1953524632 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sdb, sector 1953524608 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS kernel: device offline error, dev sdb, sector 1953524616 op 0x0:(READ) flags 0x4000 phys_seg 1 prio class 2
2024-11-30T08:10:53+0000 piNAS omv-engined[2029295]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sda’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sda: No such device or address (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029296]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdb’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdb: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029296]: Executing background process failed: Device ‘/dev/sdb’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029301]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdd’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdd: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029301]: Executing background process failed: Device ‘/dev/sdd’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029295]: Executing background process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; udevadm info --query=property --name=’/dev/sda’ 2>&1’ with exit code ‘1’: Unknown device “/dev/sda”: No such device (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029319]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdb’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdb: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029319]: Executing background process failed: Device ‘/dev/sdb’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:53+0000 piNAS kernel: sd 1:0:0:0: [sdb] Synchronizing SCSI cache
2024-11-30T08:10:53+0000 piNAS kernel: sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x04 driverbyte=DRIVER_OK
2024-11-30T08:10:53+0000 piNAS kernel: sd 3:0:0:0: [sdd] Synchronizing SCSI cache
2024-11-30T08:10:53+0000 piNAS kernel: sd 3:0:0:0: [sdd] Synchronize Cache(10) failed: Result: hostbyte=0x04 driverbyte=DRIVER_OK
2024-11-30T08:10:53+0000 piNAS omv-engined[2029324]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sdd’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sdd: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029324]: Executing background process failed: Device ‘/dev/sdd’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029318]: Executing async process failed: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; blockdev --getsize64 ‘/dev/sda’ 2>&1’ with exit code ‘1’: blockdev: cannot open /dev/sda: No such file or directory (file=/usr/share/php/openmediavault/system/process.inc, line=247)
2024-11-30T08:10:53+0000 piNAS omv-engined[2029318]: Executing background process failed: Device ‘/dev/sda’ does not exist. (file=/usr/share/php/openmediavault/system/blockdevice.inc, line=76)
2024-11-30T08:10:53+0000 piNAS kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
2024-11-30T08:10:53+0000 piNAS kernel: sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x04 driverbyte=DRIVER_OK
2024-11-30T08:10:53+0000 piNAS monit[1260]: ‘piNAS’ cpu I/O wait of 95.3% matches resource limit [cpu I/O wait > 95.0%]
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Disk failure on sda, disabling device.
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Cannot continue operation (2/4 failed).
2024-11-30T08:10:57+0000 piNAS (udev-worker)[2035766]: sda: Process ‘/sbin/mdadm -If sda --path platform-1000110000.pcie-pci-0000:01:00.0-ata-1.0’ failed with exit code 1.
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Disk failure on sdb, disabling device.
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Cannot continue operation (3/4 failed).
2024-11-30T08:10:57+0000 piNAS (udev-worker)[2035767]: sdb: Process ‘/sbin/mdadm -If sdb --path platform-1000110000.pcie-pci-0000:01:00.0-ata-2.0’ failed with exit code 1.
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Disk failure on sdd, disabling device.
2024-11-30T08:10:57+0000 piNAS kernel: md/raid:md0: Cannot continue operation (4/4 failed).
2024-11-30T08:10:57+0000 piNAS (udev-worker)[2035774]: sdd: Process ‘/sbin/mdadm -If sdd --path platform-1000110000.pcie-pci-0000:01:00.0-ata-4.0’ failed with exit code 1.
DMESG
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524608 on sda).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524616 on sda).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524624 on sda).
2024-11-30T08:10:53+0000 piNAS kernel: md/raid:md0: read error not correctable (sector 1953524632 on sda).
