In misc.py, I think the function fan_temp2dc should be
def fan_temp2dc(t):
for lv, dc in lv2dc.items():
if t >= conf[‘fan’][lv]:
return dc
return 0
This way the fans are off until lv0 is reached then they start up and step up though lv1, lv2, lv3 etc. I also (for a pi4) default them in /etc/rockpi-sata.conf to 55, 60, 65, & 70 (as my pi4 seems to idle at around 50c) so all is quiet until some stress is applied
I think this demonstrates the problem, I want the fan to start only when the lv0 temp is reached.
Breaking out of the loop and doing “return dc” will always return the last value dc held (i.e. 25)
(in my opinion dc should be out of scope at this point and throw an error but that is python!!)
'return’ing a value from within a loop within a function is fine? (though it obviously ends the loop)
Anyway this demonstrates that the existing function will always return 25 and therefore that the fan will
always be running - perhaps that is by design? but in my case I am happy with it remaining off until
lv0 (55c for me) is reached)
Just to add - my kit built and worked perfectly without any problems, it has a mix of SSD and
HDD drives and idles at about 52c (with the fan off)
My wish for a v2 board would be to have it powered on at start (without needing GPIO) so that the Pi
could USB boot but that is not a big issue as I might have kept all software on the SD card anyway
for easy recovery.
