Hi I’d like to power 4 x 3.5 HDDs on the hat directly from the ATX PSU - which already has the required connectors, instead of going through the hat. I can still power the hat with the floppy connector of the PSU, but would like the HDD power to go straight from the PSU.
many thanks for your post, i like to use the same option: powering the HAT through the floppy connector of a ATX psu and also tested the same yesterday.
I am just not sure if the psu might be broken but how can i switch on the PI/Hat once connected or do i need to add a power switch in-between?
Do you might be able to post a picture how does it look on your configuration?
Hi, @setq almost same setup (sata hdds powered directly) but is it possible to use 2 seperate psu s for taco+ssd+pi and hdds?
The idea would be to use a smaller psu (efficient for low wattage) for pi+taco+ssd running 24/7 and another psu with more power for when I need access to the harddrives as well, which would happen quite rarely. So the goal is to waste less energy.
