Penta SATA HAT limiting speed?
Armbian 22.08.0-trunk.0011 Jammy with bleeding edge Linux 5.18.3-rk35xx
# uname -a
Linux rock-3a 5.18.3-rk35xx #trunk.0011 SMP PREEMPT Thu Jun 9 20:34:08 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
# ls -la /sys/devices/system/cpu/cpufreq/ondemand
total 0
drwxr-xr-x 2 root root    0 июл 12 15:18 .
drwxr-xr-x 4 root root    0 июн 28 13:17 ..
-rw-r--r-- 1 root root 4096 июл 12 15:18 ignore_nice_load
-rw-r--r-- 1 root root 4096 июл 12 15:18 io_is_busy
-rw-r--r-- 1 root root 4096 июл 12 15:18 powersave_bias
-rw-r--r-- 1 root root 4096 июл 12 15:18 sampling_down_factor
-rw-r--r-- 1 root root 4096 июл 12 15:18 sampling_rate
-rw-r--r-- 1 root root 4096 июл 12 15:18 up_threshold
# iozone -e -I -a -s 1000M -r 1024k -r 16384k -i 0 -i 1
        Iozone: Performance Test of File I/O
                Version $Revision: 3.489 $
                Compiled for 64 bit mode.
                Build: linux
        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
                     Al Slater, Scott Rhine, Mike Wisner, Ken Goss
                     Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
                     Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
                     Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
                     Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
                     Vangel Bojaxhi, Ben England, Vikentsi Lapa,
                     Alexey Skidanov, Sudhir Kumar.
        Run began: Tue Jul 12 15:23:33 2022
        Include fsync in write timing
        O_DIRECT feature enabled
        Auto Mode
        File size set to 1024000 kB
        Record Size 1024 kB
        Record Size 16384 kB
        Command line used: iozone -e -I -a -s 1000M -r 1024k -r 16384k -i 0 -i 1
        Output is in kBytes/sec
        Time Resolution = 0.000001 seconds.
        Processor cache size set to 1024 kBytes.
        Processor cache line size set to 32 bytes.
        File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
         1024000    1024   402056   410952   371914   372100
         1024000   16384   465111   493754   482965   483448
iozone test complete.
