Installed raspbian lite and ran the script, got sata 1 and 2 to show but 3 and 4 do not. Did the OMV stuff even though im not using it just to see, nothing changed. oh and only 3 of the 4 LEDs light up.
Anyone got an idea?
Anyone got an idea?
lsusb lsblk dmesg
pi@raspberrypi:~ $ lsusb
Bus 002 Device 006: ID 1058:0a10 Western Digital Technologies, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1532:011a Razer USA, Ltd BlackWidow Ultimate 2013
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
pi@raspberrypi:~ $ ^M Show usage and help
-bash: $‘\r’: command not found
pi@raspberrypi:~ $ lsblk
sda 8:0 0 1.8T 0 disk
sdb 8:16 0 1.8T 0 disk
mmcblk0 179:0 0 59.5G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 59.2G 0 part /
pi@raspberrypi:~ $ dmesg
[ 0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:0D:82:A0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=1a1f7887-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 691 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 861 kB)
[ 0.000000] ftrace: allocating 28928 entries in 85 pages
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000022] Switching to timer-based delay loop, resolution 18ns
[ 0.000261] Console: colour dummy device 80x30
[ 0.000740] console [tty1] enabled
[ 0.000794] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000831] pid_max: default: 32768 minimum: 301
[ 0.001114] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001146] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001913] CPU: Testing write buffer coherency: ok
[ 0.002339] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002998] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003181] rcu: Hierarchical SRCU implementation.
[ 0.004075] smp: Bringing up secondary CPUs …
[ 0.004938] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005907] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006819] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006938] smp: Brought up 1 node, 4 CPUs
[ 0.007006] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.007029] CPU: All CPU(s) started in HYP mode.
[ 0.007050] CPU: Virtualization extensions available.
[ 0.007896] devtmpfs: initialized
[ 0.018728] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.018957] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018998] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.026418] pinctrl core: initialized pinctrl subsystem
[ 0.027355] NET: Registered protocol family 16
[ 0.030561] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.032107] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.032138] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032361] Serial: AMBA PL011 UART driver
[ 0.035627] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050032] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-05-11 18:59, variant start
[ 0.060047] raspberrypi-firmware soc:firmware: Firmware hash is 21bfdeee3a6ea823e2113b983390acd1eec8edfb
[ 0.102727] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.105946] vgaarb: loaded
[ 0.106341] SCSI subsystem initialized
[ 0.106556] usbcore: registered new interface driver usbfs
[ 0.106622] usbcore: registered new interface driver hub
[ 0.106707] usbcore: registered new device driver usb
[ 0.108115] clocksource: Switched to clocksource arch_sys_counter
[ 0.187170] VFS: Disk quotas dquot_6.6.0
[ 0.187279] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.187487] FS-Cache: Loaded
[ 0.187694] CacheFiles: Loaded
[ 0.188375] simple-framebuffer 3e4e0000.framebuffer: framebuffer at 0x3e4e0000, 0x6e7000 bytes, mapped to 0x(ptrval)
[ 0.188414] simple-framebuffer 3e4e0000.framebuffer: format=a8r8g8b8, mode=1824x984x32, linelength=7296
[ 0.198246] Console: switching to colour frame buffer device 228x61
[ 0.206938] simple-framebuffer 3e4e0000.framebuffer: fb0: simplefb registered!
[ 0.216122] NET: Registered protocol family 2
[ 0.216853] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.216958] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.217095] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.217235] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.217422] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.217510] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.217773] NET: Registered protocol family 1
[ 0.218410] RPC: Registered named UNIX socket transport module.
[ 0.218482] RPC: Registered udp transport module.
[ 0.218539] RPC: Registered tcp transport module.
[ 0.218595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.218671] PCI: CLS 0 bytes, default 64
[ 0.220524] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.222786] Initialise system trusted keyrings
[ 0.223042] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.232378] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.232977] NFS: Registering the id_resolver key type
[ 0.233062] Key type id_resolver registered
[ 0.233119] Key type id_legacy registered
[ 0.233183] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.237822] Key type asymmetric registered
[ 0.237886] Asymmetric key parser ‘x509’ registered
[ 0.238051] bounce: pool size: 64 pages
[ 0.238226] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.238478] io scheduler noop registered
[ 0.241129] io scheduler deadline registered (default)
[ 0.243913] io scheduler cfq registered
[ 0.246503] io scheduler mq-deadline registered (default)
[ 0.249121] io scheduler kyber registered
[ 0.285113] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.287696] brcm-pcie fd500000.pcie: could not get clock
[ 0.290377] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.292994] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff → 0xf8000000
[ 0.348139] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.350967] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.353398] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.355917] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.358527] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.358669] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.361475] PCI: bus0: Fast back to back transfers disabled
[ 0.364008] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.366742] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.366867] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.367184] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.369977] PCI: bus1: Fast back to back transfers disabled
[ 0.372539] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.372588] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.375180] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.377803] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.380407] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.383243] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 0.385914] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 0.388685] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 0.391424] pci 0000:01:00.0: enabling device (0140 → 0142)
[ 0.398284] iproc-rng200 fe104000.rng: hwrng registered
[ 0.401074] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.404092] vc-sm: Videocore shared memory driver
[ 0.407083] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.420119] brd: module loaded
[ 0.432714] loop: module loaded
[ 0.435946] Loading iSCSI transport class v2.0-870.
[ 0.440260] libphy: Fixed MDIO Bus: probed
[ 0.443202] bcmgenet fd580000.genet: failed to get enet clock
[ 0.445719] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.448252] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.450711] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.453036] bcmgenet: Skipping UMAC reset
[ 0.455688] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.478147] libphy: bcmgenet MII bus: probed
[ 0.518672] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.522014] usbcore: registered new interface driver r8152
[ 0.524520] usbcore: registered new interface driver lan78xx
[ 0.527020] usbcore: registered new interface driver smsc95xx
[ 0.529813] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.532253] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.536805] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.539589] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 0.542856] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.545322] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.547792] usb usb1: Product: xHCI Host Controller
[ 0.550286] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.552634] usb usb1: SerialNumber: 0000:01:00.0
[ 0.555598] hub 1-0:1.0: USB hub found
[ 0.558147] hub 1-0:1.0: 1 port detected
[ 0.561037] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.563463] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.565889] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.568680] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.571108] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.573580] usb usb2: Product: xHCI Host Controller
[ 0.576045] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.578507] usb usb2: SerialNumber: 0000:01:00.0
[ 0.581439] hub 2-0:1.0: USB hub found
[ 0.583909] hub 2-0:1.0: 4 ports detected
[ 0.587388] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.590019] dwc_otg: FIQ enabled
[ 0.590029] dwc_otg: NAK holdoff enabled
[ 0.590037] dwc_otg: FIQ split-transaction FSM enabled
[ 0.590051] Module dwc_common_port init
[ 0.590283] usbcore: registered new interface driver uas
[ 0.592804] usbcore: registered new interface driver usb-storage
[ 0.595386] mousedev: PS/2 mouse device common for all mice
[ 0.598996] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.602943] sdhci: Secure Digital Host Controller Interface driver
[ 0.605289] sdhci: Copyright(c) Pierre Ossman
[ 0.608001] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.610845] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.616285] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.618726] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.621205] usbcore: registered new interface driver usbhid
[ 0.623550] usbhid: USB HID core driver
[ 0.626676] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.631019] [vc_sm_connected_init]: start
[ 0.641099] [vc_sm_connected_init]: end - returning 0
[ 0.644647] Initializing XFRM netlink socket
[ 0.647015] NET: Registered protocol family 17
[ 0.649457] Key type dns_resolver registered
[ 0.652053] Registering SWP/SWPB emulation handler
[ 0.654920] registered taskstats version 1
[ 0.657208] Loading compiled-in X.509 certificates
[ 0.666553] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.668898] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.676377] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.679332] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.682414] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.684807] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.711312] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.713862] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.735665] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.739660] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.743613] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.748829] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.751410] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.755129] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.756082] of_cfs_init
[ 0.760042] of_cfs_init: OK
[ 0.762996] Waiting for root device PARTUUID=1a1f7887-02…
[ 0.807672] random: fast init done
[ 0.844365] mmc1: new high speed SDIO card at address 0001
[ 0.862934] mmc0: new ultra high speed DDR50 SDXC card at address e624
[ 0.866444] mmcblk0: mmc0:e624 SE64G 59.5 GiB
[ 0.869932] mmcblk0: p1 p2
[ 0.880425] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 0.882789] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 0.928157] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.098213] EXT4-fs (mmcblk0p2): recovery complete
[ 1.102974] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.105376] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.110788] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.113217] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.115601] usb 1-1: Product: USB2.0 Hub
[ 1.119353] devtmpfs: mounted
[ 1.122241] hub 1-1:1.0: USB hub found
[ 1.124852] hub 1-1:1.0: 4 ports detected
[ 1.134919] Freeing unused kernel memory: 2048K
[ 1.137470] Run /sbin/init as init process
[ 1.511392] systemd[1]: System time before build time, advancing clock.
[ 1.593117] NET: Registered protocol family 10
[ 1.596804] Segment Routing with IPv6
[ 1.630978] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.637136] systemd[1]: Detected architecture arm.
[ 1.659393] systemd[1]: Set hostname to .
[ 2.243291] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.254185] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.262538] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.268953] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.271579] systemd[1]: Reached target Swap.
[ 2.283477] systemd[1]: Listening on Syslog Socket.
[ 2.291144] systemd[1]: Created slice User and Session Slice.
[ 2.297949] systemd[1]: Listening on udev Kernel Socket.
[ 2.305600] systemd[1]: Created slice system-getty.slice.
[ 2.313099] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.048016] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.175483] systemd-journald[135]: Received request to flush runtime journal from PID 1
[ 3.641863] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 3.643727] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 3.645445] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 3.648032] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 3.661072] Driver for 1-wire Dallas network protocol.
[ 3.680882] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.756270] media: Linux media interface: v0.10
[ 3.776719] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.779160] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.779179] [vc_sm_connected_init]: start
[ 3.787397] [vc_sm_connected_init]: installed successfully
[ 3.792185] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.796701] videodev: Linux video capture interface: v2.00
[ 3.812967] bcm2835_audio soc:audio: card created with 4 channels
[ 3.823908] bcm2835_audio soc:audio: card created with 4 channels
[ 3.867251] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.868028] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.888851] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.941744] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.003837] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.051486] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.051522] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.097759] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.097801] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.108807] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.108844] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.158779] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.164732] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.164751] checking generic (3e4e0000 6e7000) vs hw (0 ffffffffffffffff)
[ 4.164762] fb: switching to vc4drmfb from simple
[ 4.165041] Console: switching to colour dummy device 80x30
[ 4.169436] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.169451] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.169461] [drm] No driver support for vblank timestamp query.
[ 4.169470] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.204587] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.267112] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.278361] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.278996] usbcore: registered new interface driver brcmfmac
[ 4.377403] Console: switching to colour frame buffer device 240x67
[ 4.415215] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 4.534843] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.548204] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 5.458582] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 5.568196] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 5.719825] usb 1-1.4: New USB device found, idVendor=1532, idProduct=011a, bcdDevice= 2.00
[ 5.719841] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.719854] usb 1-1.4: Product: Razer BlackWidow Ultimate
[ 5.719866] usb 1-1.4: Manufacturer: Razer
[ 5.733690] input: Razer Razer BlackWidow Ultimate as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1532:011A.0001/input/input0
[ 5.798830] hid-generic 0003:1532:011A.0001: input,hidraw0: USB HID v1.11 Keyboard [Razer Razer BlackWidow Ultimate] on usb-0000:01:00.0-1.4/input0
[ 5.809743] input: Razer Razer BlackWidow Ultimate Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:011A.0002/input/input1
[ 5.878482] input: Razer Razer BlackWidow Ultimate Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:011A.0002/input/input2
[ 5.878673] input: Razer Razer BlackWidow Ultimate System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:011A.0002/input/input3
[ 5.878836] input: Razer Razer BlackWidow Ultimate as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:011A.0002/input/input4
[ 5.879064] hid-generic 0003:1532:011A.0002: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer BlackWidow Ultimate] on usb-0000:01:00.0-1.4/input1
[ 5.886818] input: Razer Razer BlackWidow Ultimate as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:1532:011A.0003/input/input5
[ 5.887219] hid-generic 0003:1532:011A.0003: input,hidraw2: USB HID v1.11 Mouse [Razer Razer BlackWidow Ultimate] on usb-0000:01:00.0-1.4/input2
[ 6.144287] 8021q: 802.1Q VLAN Support v1.8
[ 6.455623] random: crng init done
[ 6.455637] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.495660] uart-pl011 fe201000.serial: no DMA platform data
[ 6.665609] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.992401] bcmgenet: Skipping UMAC reset
[ 7.088801] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.089135] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.582877] i2c /dev entries driver
[ 8.168244] bcmgenet fd580000.genet eth0: Link is Down
[ 10.058312] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 10.058592] usb usb2-port1: attempt power cycle
[ 11.288322] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.288435] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.138659] Bluetooth: Core ver 2.22
[ 13.138741] NET: Registered protocol family 31
[ 13.138751] Bluetooth: HCI device and connection manager initialized
[ 13.138774] Bluetooth: HCI socket layer initialized
[ 13.138791] Bluetooth: L2CAP socket layer initialized
[ 13.138843] Bluetooth: SCO socket layer initialized
[ 13.156361] Bluetooth: HCI UART driver ver 2.3
[ 13.156377] Bluetooth: HCI UART protocol H4 registered
[ 13.156482] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.158536] Bluetooth: HCI UART protocol Broadcom registered
[ 13.322421] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.322430] Bluetooth: BNEP filters: protocol multicast
[ 13.322442] Bluetooth: BNEP socket layer initialized
[ 14.758214] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 19.118230] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 19.118449] usb usb2-port1: unable to enumerate USB device
[ 19.488413] usb 2-2: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
[ 19.529704] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 19.529711] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 19.529717] usb 2-2: Product: JMS56x Series
[ 19.529721] usb 2-2: Manufacturer: JMicron
[ 19.529726] usb 2-2: SerialNumber: 1234567890123
[ 19.543697] scsi host0: uas
[ 19.546460] scsi 0:0:0:0: Direct-Access MARSHAL MAL22000SA-T54 8136 PQ: 0 ANSI: 6
[ 19.548742] scsi 0:0:0:1: Direct-Access MARSHAL MAL22000SA-T54 8136 PQ: 0 ANSI: 6
[ 19.549384] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 19.549652] sd 0:0:0:0: [sda] Write Protect is off
[ 19.549664] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 19.550635] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 19.551400] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 19.551555] sd 0:0:0:1: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 19.552773] sd 0:0:0:1: [sdb] Write Protect is off
[ 19.552781] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 19.553349] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 19.554151] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 20.143731] sd 0:0:0:0: [sda] Attached SCSI disk
[ 20.145498] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 20.358215] usb 1-1.1: new high-speed USB device number 4 using xhci_hcd
[ 21.308416] usb 1-1-port1: Cannot enable. Maybe the USB cable is bad?
[ 21.408120] usb 1-1.1: new high-speed USB device number 5 using xhci_hcd
[ 23.888200] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 28.428214] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 32.778180] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 32.778436] usb usb2-port1: attempt power cycle
[ 37.478208] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 41.818196] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 41.818457] usb usb2-port1: unable to enumerate USB device
[ 46.138182] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 50.678183] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 55.018185] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 55.018443] usb usb2-port1: attempt power cycle
[ 59.698186] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 64.038198] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 64.038452] usb usb2-port1: unable to enumerate USB device
[ 68.358187] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 72.894697] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 77.231426] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 77.231673] usb usb2-port1: attempt power cycle
[ 81.908695] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 86.246845] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 86.247102] usb usb2-port1: unable to enumerate USB device
[ 90.565435] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 95.114341] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 99.453536] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 99.453785] usb usb2-port1: attempt power cycle
[ 104.132905] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 108.472458] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 108.472711] usb usb2-port1: unable to enumerate USB device
[ 112.792200] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 117.331837] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 121.671662] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 121.671917] usb usb2-port1: attempt power cycle
[ 126.351496] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 130.691398] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 130.691649] usb usb2-port1: unable to enumerate USB device
[ 130.773238] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 130.774466] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 135.012468] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 139.555213] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 143.907495] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 143.907812] usb usb2-port1: attempt power cycle
[ 148.589679] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 152.941494] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 152.941790] usb usb2-port1: unable to enumerate USB device
[ 157.263096] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[ 161.804601] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
pi@raspberrypi:~ $
It looks like a bad connection. It might look something like this Quad SATA Hat doesn't recognise two disks
Maybe try suppressing junk from serial.sh:
On my box I get this with the default serial.sh:
/sbin/hdparm -I /dev/sda | grep ‘Serial Number’ | awk ‘{print $3}’ SG_IO: bad/missing sense data, sb: 70 00 0b 00 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
5AA0BBCC
Made a small tweak to suppress the noise:
/sbin/hdparm -I /dev/sda 2> /dev/null | grep ‘Serial Number’ | awk ‘{print $3}’
5AA0BBCC
JJ
