Just tried my new Rock 5 but can’t get a HDMI signal. Tried multiple chargers with PD and without. The only thing I can see is the green LED and I’ve managed to get the device into Mask Mode or whatever it’s called.
I’m having same issue. I can SSH into the R5B but can not get hdmi out. I thought it was my PD but after 8 different PDs and 2 constant power adapters (12v4a) tried Advanced IP scan and found R5B on network. SSH into it and it works great… except I can not get HDMI out.
(Clarification…only issue after apt update and apt upgrade. I have HDMI before this step. Afterwards, no video out)
In your case: what’s the resolution of the monitor you’ve got plugged in? I know the board supports 4K HDMI resolutions, but it doesn’t seem to be enabled out of the box.
There’s a solution over in this thread:
I’m running with dual 1440p displays and, after adding the DTB overlay listed there, not having any issues.
Solved…it was my monitor. It’s my bench monitor age 15+ years old. It has been reliable for all my system testing until now. It still works with my windows boxes…just an issue with my Rock SBCs.
Anyway, 100% with my R5B.
Had a lot to learn. But now the board is up and running. Booting from NVME (no SD card) and with h/w acceleration enabled -snappy desktop, chromium and 4k playback in kodi. My use case is a little chromium, qbittorrent, remote desktop and file sharing (via SMB) -not really using this device for media playback as I have both a Nvida Shield TV Tube and the new Apple TV 4k (kodi and infuse) but more as a 24/7 power efficient desktop connected to my LG OLED TV in the living room.
I’m using ,
and very happy with it -no problems with booting from the NMVE without SD card as with other releases.
Waiting for the ROCK 5B METAL CASE to be available again -I’m running with the blue little passive heatsink and the temperatures could be a bit better.
