Hello friends!
Thanks to generous Radxa, they sent me an ROCK 5B Plus for testing ![]()
I would like to give a quick preview of the board with you.
The board on my hand is version X1.1 and the details are subjected to changes.
For those I know,
SoC would be our old friend RK3588.
For RAM, the board on my hand is 2 x K3LKBKB0BM-MGCP(32 Gb)
LPDDR5,which give a total of 8GB.
This time we have wifi on board, which is Azurewave AW-XM548NF, which support WIFI 6 AX.
The USB Type-C power input port this time would trigger PD-12V, which should eliminate a lots of power related problems. ![]()
It also got 2 HDMI out and 1 HDMI in ports, at standrad size.
There is a raised 2242 B-key slot on front with PCIE 2.1 x1 lane and TWO m.2 2280 slots at the back! (PCIE 3.0 x2 + x2).
It would be perfect for NAS I bet ![]()
In additions, I see two CSI, one DSI, and a SIM Card slot at the back for modem.
For eMMC, it has got on-board 8GB from FORESEE.
Update: RAM test is added
To see if there is material improvement in RAM speed, sysbench ram test was performed on Rock5B and Rock5B Plus with results as follow:
Rock5B Plus RAM Write: 11359.78 MiB/sec
rock@rock-5b-plus:~$ sysbench memory --memory-block-size=1G --memory-total-size=
20G --memory-oper=write run
sysbench 1.0.20 (using system LuaJIT 2.1.0-beta3)
Running the test with following options:
Number of threads: 1
Initializing random number generator from current time
Running memory speed test with the following options:
block size: 1048576KiB
total size: 20480MiB
operation: write
scope: global
Initializing worker threads...
Threads started!
Total operations: 20 ( 11.09 per second)
20480.00 MiB transferred ( 11359.78 MiB/sec )
General statistics:
total time: 1.8012s
total number of events: 20
Latency (ms):
min: 88.65
avg: 90.04
max: 115.59
95th percentile: 89.16
sum: 1800.89
Threads fairness:
events (avg/stddev): 20.0000/0.00
execution time (avg/stddev): 1.8009/0.00
Rock5B RAM Write: 11807.97 MiB/sec
rock@rock-5b:~$ sysbench memory --memory-block-size=1G --memory-total-size=20G --memory-
oper=write run
operation: write
scope: global
Threads started!
Total operations: 20 ( 11.53 per second)
20480.00 MiB transferred (11807.97 MiB/sec)
General statistics:
total time: 1.7328s
Latency (ms):
min: 85.44
avg: 86.62
max: 106.14
95th percentile: 86.00
sum: 1732.49
Threads fairness:
execution time (avg/stddev): 1.7325/0.00
Rock5B Plus RAM Read: 15481.64 MiB/sec
rock@rock-5b-plus:~$ sysbench memory --memory-block-size=1G --memory-total-size=20G --memory-oper=read run
operation: read
scope: global
Threads started!
Total operations: 20 ( 15.12 per second)
20480.00 MiB transferred (15481.64 MiB/sec)
General statistics:
total time: 1.3212s
Latency (ms):
min: 63.50
avg: 66.04
max: 112.05
95th percentile: 63.32
sum: 1320.79
Threads fairness:
execution time (avg/stddev): 1.3208/0.00
Rock5B RAM Read: 10361.02 MiB/sec
rock@rock-5b:~$ sysbench memory --memory-block-size=1G --memory-total-size=20G --memory-oper=read run
operation: read
scope: global
Threads started!
Total operations: 20 ( 10.12 per second)
20480.00 MiB transferred (10361.02 MiB/sec)
General statistics:
total time: 1.9674s
Latency (ms):
min: 97.41
avg: 98.34
max: 112.99
95th percentile: 97.55
sum: 1966.74
Threads fairness:
execution time (avg/stddev): 1.9667/0.00
The result look divergence. ![]()
