New Custom Debian ARM64 Build 4.4.154.c83 is finally here!
Hay now hold your horses there… :wink:
thx for your work O635789.
Are you still working on the Bluetooth issue?
Hope you get it fixed, because i loost my audiojack a the first day :frowning:
That´s realy a bad work from Radxa, but i still love the RockPi 4 :wink:
For the bluetooth, please check:
Ubuntu Server Image, No Bluetooth - #13 by jack
Thanks for the reminder, I’ve been distracted by other projects, I’ll revisit the Bluetooth issue soon. Bottom line is HDMI audio works as I tested, besides I’m adding an amplifier HAT to power a surface transducer to use as smart speaker, it could be a substitute of the 3.5mm jack too.
HDMI CEC is merged into the kernel already long time ago. Yes, rockpi4-full is a good idea for user who have all the ROCK Pi 4 accessories :slight_smile:
This indeed looks very nice, but where/how can I get linux-headers that match this custom kernel?
cifs.ko is missing. How may I add it?
Alternatively, how may I mount a samba share?
Just wanted to note that, I installed on a 64GB uSD v30 A2(!) card, and the Rock Pi boots to desktop with this distro before my monitor registers the signal from hdmi and show me an image :smiley:
Awesome work, well done.
Hi there,
Thank you for this image!
Could anyone please help me with the following two questions (The answer might also be usefull to add to the wiki):
  1. How can i connect to the rockpi over usb from a linux system (chromeos in my case)
  2. Is there any elegant way to change the username while retaining the nice configuration of the desktop ?
Thank you in advance
https://wiki.radxa.com/Rockpi4/dev/usbnet
Great Work!!! I’ll try this today and hope everything goes smoothly
Hi. Can you start from nvme with this distribution?
Hi. I managed to boot from NVME perfectly. I really like the appearance achieved. Now, the problem came when doing an update / upgrade. There were errors in the update, and I failed to fix it. Can someone guide me in this problem? Thank you
Hi. I make a query. To install vlc, did you first have to do sudo apt-get update / upgrade? what’s mean of: if you run “sudo apt upgrade” without any protection?How do that? In My case, is the second try, the first broken the system.
