Yeah master works but also did drm.
Quick run down as the above is for a debian/ubuntu or something
sudo pacman -S bc python-pip flex bison base-devel ncurses cmake xorg-util-macros
sudo pip install scikit-build mako meson ninja
git clone https://gitlab.freedesktop.org/mesa/drm.git --depth=1
cd drm
./autogen.sh
./configure --prefix=/usr
make -j6
sudo make install
cd ..
git clone https://gitlab.freedesktop.org/mesa/mesa.git --depth=1
cd mesa
mkdir build
meson -Ddri-drivers= -Dvulkan-drivers= -Dgallium-drivers=panfrost,kmsro -Dlibunwind=false -Dplatforms=x11,drm,surfaceless -Dprefix=/usr build/
ninja -C build/
sudo ninja -C build/ install
As long as you removed the fbturbo package reboot and there you go
[rock@rockpi4 ~]$ glmark2
glmark2 2014.03
OpenGL Information
GL_VENDOR: panfrost
GL_RENDERER: panfrost
GL_VERSION: 2.1 Mesa 19.1.2 (git-fe1f7b538b)
[build] use-vbo=false: FPS: 164 FrameTime: 6.098 ms
[build] use-vbo=true: FPS: 382 FrameTime: 2.618 ms
[texture] texture-filter=nearest: FPS: 394 FrameTime: 2.538 ms
[texture] texture-filter=linear: FPS: 394 FrameTime: 2.538 ms
[texture] texture-filter=mipmap: FPS: 391 FrameTime: 2.558 ms
[shading] shading=gouraud: FPS: 328 FrameTime: 3.049 ms
[shading] shading=blinn-phong-inf: FPS: 328 FrameTime: 3.049 ms
[shading] shading=phong: FPS: 296 FrameTime: 3.378 ms
[shading] shading=cel: FPS: 239 FrameTime: 4.184 ms
[bump] bump-render=high-poly: FPS: 196 FrameTime: 5.102 ms
[bump] bump-render=normals: FPS: 414 FrameTime: 2.415 ms
[bump] bump-render=height: FPS: 402 FrameTime: 2.488 ms
libpng warning: iCCP: known incorrect sRGB profile
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 381 FrameTime: 2.625 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 186 FrameTime: 5.376 ms
[pulsar] light=false:quads=5:texture=false: FPS: 415 FrameTime: 2.410 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4:glmark2: ../src/util/ralloc.c:91: get_header: Assertion `info->canary == CANARY' failed.
Aborted (core dumped)
Dunno if that is me compiling glmark2 from aur wrong or panfrost.
rock@rockpi4 glmark2]$ vblank_mode=0 glxgears
ATTENTION: default value of option vblank_mode overridden by environment.
5384 frames in 5.0 seconds = 1076.761 FPS
5361 frames in 5.0 seconds = 1072.048 FPS
5554 frames in 5.0 seconds = 1110.738 FPS
5602 frames in 5.0 seconds = 1120.345 FPS
5608 frames in 5.0 seconds = 1121.375 FPS
5634 frames in 5.0 seconds = 1126.753 FPS
5653 frames in 5.0 seconds = 1130.372 FPS
5640 frames in 5.0 seconds = 1127.873 FPS
5700 frames in 5.0 seconds = 1139.857 FPS
5600 frames in 5.0 seconds = 1119.792 FPS
