https://lkml.org/lkml/2019/6/13/488
Its looking like for complete mainline without overlays it could be 5.3
Nice progress ![]()
In kernel 5.1 we have:
In kernel 5.2 we have:
In kernel 5.3 weāll have:
So, from 5.3 on these should work:
Also, uboot has first support:
[U-Boot] rockchip: rk3399: Add Rock PI 4 support
and LPDDR4 support is sent to the mailing list.
Yeah the KDE version with 5.1 seems to be wifi/bt, pcie and audio over HDMI.
I havenāt tried but the Mali module hasnāt been configured and prob needs a recompile to allow the addition of the rockchip midgard driver, until panfrost 5.2.
Prob being a first inclusion it may not be a smooth ride with panfrost but you never know ![]()
Also there is the Armbian version Updated images for Rock Pi 4 - Announcements - Armbian Community Forums but havenāt tried that yet. I might head there next as they have some great build scripts.
5.2 which is early July I am sure some clever tinkerer can backport those few patches as it would seem time to start gearing up for mainline and long live 4.4, but ⦠![]()
I still perplexed why the DTS still has PCIe set to gen1 as didnāt notice that anywhere. Maybe its me being usually dumb but PCIe is backward compatible or is it fixed to specific gens on the rk3399?
Also Radxa and overlay support?
Nice. Iām trying to get 5.2 RC up and running in my setup (I donāt need the 5.3 features yet) but the serial console overlay from 4.4 does not work. So either I missed a kernel config option, or things have changed too much.
reading /overlays/console-on-ttyS2.dtbo
774 bytes read in 16 ms (46.9 KiB/s)
overlay dtb(0x0000000001e00000) is valid
fdt_overlay_apply 0000000001f00000 0000000001e00000
fdt_overlay_apply(): FDT_ERR_NOTFOUND
Can't load dts overlay
While it does boot without console
debugging is a whole lot easier when you have one ā¦
As not sure what uharts are in use between the 2, but overlays are not enabled in mainlineā¦
Majority of the overlay commands just enable specific hardware and hat details and are a good inclusion but for just raw kernel try without.
I have used the serial console on the manjaro images but they keep totally mainline and zero radxa packages.
You only need the overlay if you are going to have the console on another than default uhart
5.2 RC4 was freezing for a while but havenāt tested but fingers crossed looking at the patches may be fixed in RC5
Connect the USB to TTL serial cable as below. Donāt connect the red wire.
| ROCK Pi 4 | <ā> | USB to TTL cable |
| RX(pin 10) | <ā> | Green wire |
| TX(pin 8) | <ā> | White wire |
| GND(pin 6) | <ā> | Black wire |
You may have to swap round TX/RX as I can never tell which side they are supposed to relate to and you should be set to 3.3v, also ignore the colors as it varies wildly but should be marked but which end they refer to seems to be pot luck.
baudrate: 1500000
data bit: 8
stop bit: 1
parity : none
flow control: none
https://wiki.radxa.com/Rockpi4/dev/serial-console
I like coolterm if you are using windows
https://freeware.the-meiers.org/
It would be really beneficial for radxa to start supporting mainline as the specific radxa patches now needed are actually very few.
@jack
Umm, I do have a serial console which works for u-boot. And 4.4. But 5.2 is silent. Probably just wrong kernel arguments?
NB, I have a µArt TTL-serial interface. That is an isolating converter. So yes, I do need to connect its version of the red wire. ![]()
Iām sure youāve checked this already, but something that catches me out from time to time when I build board kernels is differing default baud rates between u-boot and kernel, typically u-boot set for 1.5Mbps, and then kernel compiled with something else like 115.2k or 38.4k.
Well, thatās what the kernel command line is for. If somebody could document and/or tell me which kernel config and command line is responsible for the serial console on 5.1+ Iād be grateful.
label kernel-4.4.154-59-rockchip-g5e70f14
kernel /vmlinuz-4.4.154-59-rockchip-g5e70f14
devicetreedir /dtbs/4.4.154-59-rockchip-g5e70f14
append earlyprintk console=ttyFIQ0,1500000n8 video=HDMI-A-1:1920x1080@60 init=/sbin/init root=PARTUUID=b921b045-1d rootwait rootfstype=ext4
As an example extlinux.conf
So uboot is showing but then goes quiet as prob console=ttyFIQ0,1500000n8 is missing
But it should be in journalctl
Yes, of course. Thatās kernel 4.4 ā this command line works for me. But with my 5.2 RC the kernel is quiet. In fact, I have no /dev/ttyFIC0 (or any other serial device) once itās up.
# After modifying, run ./mkscr
# MAC address (use spaces instead of colons)
setenv macaddr da 19 c8 7a 6d f4
part uuid ${devtype} ${devnum}:${bootpart} uuid
setenv bootargs console=ttyS2,1500000 root=PARTUUID=${uuid} rw rootwait
setenv fdtfile rockchip/rk3399-rock-pi-4.dtb
if load ${devtype} ${devnum}:${bootpart} ${kernel_addr_r} /boot/Image; then
if load ${devtype} ${devnum}:${bootpart} ${fdt_addr_r} /boot/dtbs/${fdtfile}; then
fdt addr ${fdt_addr_r}
fdt resize
fdt set /ethernet@fe300000 local-mac-address "[${macaddr}]"
if load ${devtype} ${devnum}:${bootpart} ${ramdisk_addr_r} /boot/initramfs-linux.img; then
# This upstream Uboot doesn't support compresses cpio initrd, use kernel option to
# load initramfs
setenv bootargs ${bootargs} initrd=${ramdisk_addr_r},20M ramdisk_size=10M
fi;
booti ${kernel_addr_r} - ${fdt_addr_r};
fi;
fi
The Manjaro guys compiled mainline and have a serial console, so guess its your compile
Thanks. That creates ttyS0 through S3, but thereās no support for earlyprintk. (Adding that option has no effect.)
Dunno maybe it also has to be in this format earlyprintk=ttyS2,1500000
also is CONFIG_DEBUG_LL and CONFIG_EARLY_PRINTK enabled in the kernel
configuration?
You might be able to root something out via the elinux site.
Well ⦠no. There is no DEBUG_LL or EARLY_PRINTK in my .config at all, because theyāre in arch/arm/Kconfig.debug, not arch/arm64/Kconfig.debug.
Kernel 4.4 did this differently, by replacing the uart2 driver with the fiq_debugger in the uartX-as-console devicetree overlay. Apparently that hasnāt yet been ported to 5.2.
You donāt need to load the console-on-ttyS2.dtbo overlay to get serial console on ttyS2 for mainline kernel. Just put your mainline kernel and mainline dtb to /boot and add the following to extlinux.conf:
label kernel-mainline
kernel /Image
fdt /rk3399-rock-pi-4.dtb
append earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=PARTUUID=b921b045-1d rootfstype=ext4 init=/sbin/init rootwait
Aaah. Thatās the ticket. Thank you! that woks and is very helpful.
Does somebody have an idea where this delay is coming from? 20 seconds seems a bit excessive.
[ 9.014036] SGI XFS with ACLs, security attributes, no debug enabled
[ 28.488075] alg: No test for lzo-rle (lzo-rle-generic)
5.2 RC5 still?
Its an RC with some big changes to large memory allocation and case insensitive ext4. Could be a huge amount of things and prob better to post in the Kernel community as by look of it until you apply compile configs for the above for SGI XFS with ACLs, security attributes to debug guess we will not know.
I donāt know very much about kernel development, so ducking out of that one waiting till early July for the release as these could be general kernel bugs and nothing specific with the RockPi4.
If that is RC5 then its better than RC4 as that overall had about 2 mins lost time at certain points.
Somewhat related:
https://twitter.com/Collabora/status/1141368101818314752
Does anyone know if pcie should be working in 5.1/5.2 as doesnāt seem to be.
Is that something that has to be patched in Uboot?
