Longer FPC cable for Rock5B Display HD?
Are there cables of a longer length for connecting the Display8/10 HD LCD panels to the Rock5B? I am trying to mount my Rock5B to the back side of the LCD display, with the NVME side (bottom of the Rock5B) facing away from the back of the LCD. This is in order to accommodate a capture card with a tall heatsink, and to avoid such a device throwing a lot of heat at the back of the LCD panel.
The current retail FPC cable is too short to properly accommodate this orientation. I attempted to orient and connect it in this way, but it caused too much strain on the cable, which shorted out the cable and blew up the Schottky barrier diode in circuit. See my post: Rock5B/Display 8HD: Magic smoke from MIPI ribbon connector, help identify burned part
Any help sourcing a longer alternate cable, or the exact specs of the cable so an alternate can be fabricated, would be appreciated. Thank you!
@melo please help to look at this question
We are going to launch a 200mm FPC cable for ROCK 5 to support 8 HD / 10 FHD.
AC013-200
200mm length.
Is that the new part number for the 200mm cable? When will it be available for purchase through the channel?
YES. you can buy it on arace.
Arace will be on sale next week.
I just burned my Rock5B board while trying to rotate it to reflash the eMMC. The FPC cable was too short, causing the 8HD display attached to it to short circuit.
