Llama.cpp - Benchmarks
Hi all,
I bought the Orion O6 primarily with the intent of running LLM’s on it (I needed something with relatively low power consumption - I run exclusively on solar).
I figure some benchmarks for Llama.cpp might interest others. Do not expect great speeds - it is constrained by the RAM bandwidth for token generation - and prompt ingestion is currently CPU-only (though would love to see how it would perform using the NPU).
A preliminary note, I built Llama.cpp using the following:
# NOTE: The use of GGML_CPU_ARM_ARCH - without this, Llama may not detect NEON/SIMD support on the Cix P1 (this was the case for the Radxa Debian image).
cmake -B build -DGGML_CPU_ARM_ARCH=armv9-a+sve2+dotprod+i8mm+fp16+fp16fml+crypto+sha2+sha3+sm4+rcpc+lse+crc+aes+memtag+sb+ssbs+predres+pauth -DCMAKE_C_COMPILER=gcc-12 -DCMAKE_CXX_COMPILER=g++-12 -DGGML_NATIVE=off
# Build it (use 6 threads)
cmake --build build --config Release -j 6
The reason for this is that Llama’s build script has some conditionals when determining the CPU feature-set (and these weren’t being detected correctly using Radxa’s Debian Image). So, it was being built without the ARM NEON kernels (this does impact prompt processing significantly). As to why that feature-list is so long - I pretty much threw the kitchen sink at it in case there were other optimizations possible (most are likely not used).
Some other quick notes:
  1. I did manage a successful build with KleidiAI support - but prompt ingestion performance did not appear to improve and token generation was actually significantly slower (tg on Qwen3 A3B:30B:Q4_K_M down to around 12 t/s).
  2. Building with Vulkan, technically, succeeded - but it freezes (or is ridiculously slow) while trying to ingest/generate tokens.
  3. 7 threads appears to be the sweet spot. Using -1 (auto), it was ridiculously slow (maybe trying to use small cores which aren’t available?)
  4. My Orion O6 is in the Radxa AI Kit case. I haven’t placed a copper plate to make better contact with the heatsink yet, so it runs a little hot (CPU B1 @ ~65C). Power consumption (according to my USB-C charger) is around ~20W when running (20V, 1A).
Benchmarks
/llama-bench -t 7 -m ../../../models/Qwen_Qwen3-30B-A3B-Q4_K_M.gguf
| model                          |       size |     params | backend    | threads |            test |                  t/s |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           pp512 |         23.31 ± 0.07 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           tg128 |         16.13 ± 0.08 |
build: cb9178f8 (5857)
# NOTE: Too slow, so only did one repeat.
./llama-bench -t 7 -m ../../../models/Qwen_Qwen3-32B-Q4_K_M.gguf -r 1
| qwen3 32B Q4_K - Medium        |  18.40 GiB |    32.76 B | CPU        |       7 |           pp512 |          3.90 ± 0.00 |
| qwen3 32B Q4_K - Medium        |  18.40 GiB |    32.76 B | CPU        |       7 |           tg128 |          1.95 ± 0.00 |
./llama-bench -t 7 -m ../../../models/Hunyuan-A13B-Instruct-Q4_K_M.gguf -r 1
| hunyuan-moe A13B Q4_K - Medium |  45.43 GiB |    80.39 B | CPU        |       7 |           pp512 |          6.65 ± 0.00 |
| hunyuan-moe A13B Q4_K - Medium |  45.43 GiB |    80.39 B | CPU        |       7 |           tg128 |          3.71 ± 0.00 |
For anyone interested, here’s an example of Qwen3 A3B:30B without NEON/SIMD.
# NOTE: Built WITHOUT NEON/SIMD
./llama-bench -t 7 -m ../../../models/Qwen_Qwen3-30B-A3B-Q4_K_M.gguf
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           pp512 |         14.85 ± 0.03 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           tg128 |         12.41 ± 0.01 |
Just a small update on the status of Llama.cpp with Orion O6 + Vulkan:
Technically, Vulkan can “kind of” work. But it’s far slower than CPU.
I found that tweaking:
  1. The -ngl parameter to zero (llama-bench defaults to 99) so that no layers are offloaded and…
  2. The -b(atch) parameter to a low number (e.g. 16)
I was able to successfully run llama-bench. Performance is far below CPU though. For example, Qwen3-32B sat at around 2 t/s for Prompt Processing and Token Gen was around 1.1 t/s or something. Versus CPU which is around 4 t/s and 2 t/s.
This was tested using the Radxa Debian Image, so perhaps there are system config tweaks that can improve performance. Maybe it’s related to the UMA architecture and how the GPU is allowed to access the shared memory?
So are you more satisfied using this quant?
I’m actually really impressed by the latest Qwen3-30B-A3B released on 2025-07-25:
https://huggingface.co/bartowski/Qwen_Qwen3-30B-A3B-Instruct-2507-GGUF
In terms of Q4_K_M, I went with that quant because it seems to be a good trade-off in terms of perplexity loss and performance. In my experience, for simple queries, Q4 is typically good enough.
If we go for larger quants:
  1. It would require more RAM.
  2. Token generation would be slower (e.g. a Q8 would probably halve token generation performance due to RAM bandwidth constraints on the O6).
That said, the NPU natively supports INT8, so it might be worth using a Q8 if the NPU ever becomes supported (would likely speed up Prompt Processing a lot).
There is also an ALIGNED_INT4 type in the NPU source-code, so it might be that INT4 is supported too (for efficient Prompt Processing of Q4 quants). I’m not confident on this though - if someone might be able to verify that’s the case, would appreciate it.
I don’t think the NPU SDK is in a very good state yet though. See the post here for details: C++ Example running YOLOv8 on the NPU
It might be a very long time before we’re able to use it with Llama (if ever).
Decided to try out ik_llama.cpp as I’d heard there were some optimizations for CPU (particularly for Prompt Processing). The improvement is really dramatic for PP and for Qwen30B-A3B-Instruct-2507 Q4_M, it pretty much doubles the TPS.
How to Build
git clone https://github.com/ikawrakow/ik_llama.cpp
cd ik_llama
# THIS IS IMPORTANT! MUST SET ARCH FLAGS MANUALLY!
cmake -B ./build -DGGML_CUDA=OFF -DGGML_BLAS=OFF -DCMAKE_C_FLAGS="-march=armv9-a+sve2+dotprod+i8mm+fp16+fp16fml+crypto+sha2+sha3+sm4+rcpc+lse+crc+aes+memtag+sb+ssbs+predres+pauth" -DCMAKE_CXX_FLAGS="-march=armv9-a+sve2+dotprod+i8mm+fp16+fp16fml+crypto+sha2+sha3+sm4+rcpc+lse+crc+aes+memtag+sb+ssbs+predres+pauth" -DGGML_NATIVE=off
# Build using 7 threads
cmake --build ./build --config Release -j 7
Benchmarks
ik_llama.cpp
./llama-bench -m ../../../models/Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 7
| qwen3moe ?B Q4_K - Medium      |  17.35 GiB |    30.53 B | CPU        |       7 |         pp512 |     50.51 ± 0.27 |
| qwen3moe ?B Q4_K - Medium      |  17.35 GiB |    30.53 B | CPU        |       7 |         tg128 |     15.44 ± 0.01 |
build: d99cf7cb (3836)
llama.cpp:
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           pp512 |         24.33 ± 0.06 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       7 |           tg128 |         14.94 ± 0.03 |
For some reason, I’m getting ~10% lower results for ik_llama.cpp
sh-5.2$ build/bin/llama-bench -m ../Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 7
| qwen3moe ?B Q4_K - Medium      |  17.35 GiB |    30.53 B | CPU        |       7 |         pp512 |     45.76 ± 0.85 |
| qwen3moe ?B Q4_K - Medium      |  17.35 GiB |    30.53 B | CPU        |       7 |         tg128 |     13.79 ± 0.75 |
build: e082df47 (3837)
Given a 64GB O6 board, what would be the current best local model(s) to run for coding? I would like to run aider.chat or other CLI tool on one machine and use the O6 as an LLM server. Aider supports separate “architect” and “coder” models, so it is possible to run two parallel 30B models (4 bits).
I’m not an AI expert, but would love to use the available local models.
Did you use this build command:
I’m not sure ik_llama will correctly detect/optimize-for ARM architecture otherwise (missing Neon and SVE IIRC). It might also be something to do with clock frequency - I haven’t checked what mine is running at (but I had to downgrade to an older BIOS version).
Might want to check this one out:
I really think anything beyond 3B active is probably heading into impractical speeds territory: The RAM bandwidth is just too slow for Token Generation on bigger models.
Note that the CPU optimizations don’t provide that large of a gain (with the default llama.cpp). I’ve just run llama-bench below with -mcpu=native and with -mcpu=cortex-a720+sve+dotprod which I’m normally using on this machine, the difference is around 1.5%. I’ve tested your flags and they give me the exact same results as these optimizations, and the executable is the same size as well, indicating that the compiler didn’t make use of any other feature:
build: 4227c9be (6170)
-mcpu=native first:
model size params backend threads test t/s
qwen3moe 30B.A3B Q4_1 17.89 GiB 30.53 B CPU 8 pp512 30.48 ± 0.01
qwen3moe 30B.A3B Q4_1 17.89 GiB 30.53 B CPU 8 tg128 19.90 ± 0.01
And -mcpu=cortex-a720+sve+dotprod below:
qwen3moe 30B.A3B Q4_1 17.89 GiB 30.53 B CPU 8 pp512 30.97 ± 0.00
qwen3moe 30B.A3B Q4_1 17.89 GiB 30.53 B CPU 8 tg128 20.30 ± 0.01
I didn’t know about ik_llama, I’ll have to have a look, thanks for the hint!
I just ran ik_llama on the same model and it gave me an impressive increase of PP (x2.46) but a 20% decrease in TG:
qwen3moe ?B Q4_1 17.89 GiB 30.53 B CPU 8 pp512 76.34 ± 0.33
qwen3moe ?B Q4_1 17.89 GiB 30.53 B CPU 8 tg128 16.20 ± 0.06
Maybe it changes depending on the quantization. In any case, the much faster processing is interesting when ingesting large documents or parts of code.
Could’ve sworn when I was testing, it made a significant different (~25%) due to the Neon support. Maybe I’m mis-remembering (or maybe a newer commit correctly already detects Neon support)?
Really impressed by your figures here. Have you over-clocked your board? I feel like I remember someone (may’ve been you?) talking about that in another thread. Unsure why your TG is a bit slower. On mine, it seemed to kick up very very slightly. Either way, huge improvement. Really hope we’ll eventually get good NPU support on the Orion for stuff like that. There’s an ALIGNED_INT4 type mentioned in the C code, so it might be theoretically possible to support Q4 quants.
Maybe initially you didn’t use “-mcpu=native” and gcc didn’t enable it by default ? Note also I’m using gcc-14.2, maybe a previous one doesn’t enable it ? I remember that with the initial gcc (12 or 13, I don’t remember), -mcpu=native didn’t properly detect the CPU’s features.
Yep. I have 2x3.0, 2x2.7, 2x2.6 GHz. It’s not much compared to the initially advertised frequencies :wink: After all it’s only the medium cores running at 8% higher. My RAM is set to 6400 MT/s (though it doesn’t change anything from 5500 by default), and the internal coherent interconnect bus (CI-700) was raised from 1500 to 1700 MHz (which does help make better use of the RAM BW). This does have some effect, my RAM BW jumped from 40 to 46 GB/s. Of course we’re still far from the initially expected 100 but this is due to internal limitations in the chip. My understanding is that the DSU (which contains L3) capped at 1.3 GHz limits to communications with the L3 to 1.3Gx4*256 bits = ~166 GB/s, so it should not be an issue. However it’s connected to the CI-700 by a single 256b bus, and it’s not clear to me if it’s subject to this 1.3 GHz or not. Apparently not since I’m getting 46GB/s while this whould limit it to 41 otherwise. The NPU/GPU do not pass through DSU and are directly connected to the CI-700 so the RAM BW is shared between DSU and NPU+GPU.
My understanding of the architecture (but I could be wrong) is the following:
CPU clusters --(4x256b)–> DSU-120 @1.3 GHz (L3) --(1x256b)–> CI-700 @1.5 GHz --(128b x 6.4 MT/s)–> LPDDR5.
Thus we’d have a total of ~166 GB/s to L3 (which seems to roughly match my observations) but a bottleneck of 41 or 48 GB/s to CI-700 thus RAM. It’s not entirely clear to me how other chips deal with this because DSU-CI is 256b, and CI tops to 2 GHz on 5nm chips (i.e. 64 GB/s). Maybe larger chips implement multiple CI when they have multiple memory channels, I don’t know. Or maybe it’s possible to connect multiple DSU to a single CI.
This chip remains a bit awkward with internal bottlenecks that are lower than the external ones. However we need to keep in mind that it’s built around medium cores and targets a balance between efficiency, performance and cost. For example it still achieves a higher bandwidth than with a single DRAM channel, so even if it reaches certain limitations, this stems from a set of reasonable design choices that also consider cost and power usage.
I’ve copy-pasted your build commands directly into my shell.
BTW I’ve retested on Q4_K_M to make sure we’re comparing apples to apples (I was on Q4_1 before) and PP is even slightly faster with llama:
qwen3moe 30B.A3B Q4_K - Medium 17.35 GiB 30.53 B CPU 8 pp512 34.02 ± 0.01
qwen3moe 30B.A3B Q4_K - Medium 17.35 GiB 30.53 B CPU 8 tg128 21.09 ± 0.00
With ik-llama it’s slightly slower however:
qwen3moe ?B Q4_K - Medium 17.35 GiB 30.53 B CPU 8 pp512 75.37 ± 0.38
qwen3moe ?B Q4_K - Medium 17.35 GiB 30.53 B CPU 8 tg128 14.75 ± 0.20
ik-llama isn’t super stable for me. Some models fail to load or cause random crashes, but there’s probably some good stuff to pick there for the prompt processing.
Thanks for the detail here. With the architecture you suspect of the Cix P1, do you know if this might potentially bode well for the NPU? It sounds like you might be suggesting that NPU bypasses L3 and has direct access to RAM via CI-700 (maybe I’ve misinterpreted though)? Any idea if there are any other constraints discovered as it relates to the NPU (e.g. I remember the RK3588 NPU only being able to access memory within the first 4GB range - or something to that effect).
I haven’t had ik-llama exlusive problems yet, but I do get seem to get some hard crashes while benching larger models (70B) on both ik-llama.cpp and llama.cpp. I haven’t actually done a memtest yet to see whether something might be faulty there though. If relevant, I’m using the Radxa Debian Image.
I don’t think the NPU nor the GPU will have any issues as they’re connected outside of the DSU (dynamiq shared unit), thus closer to the memory controller. For me the limitation really is between DSU and CI-700. This, if one day the NPU would ever become generally supported, we could imagine doubling the token generation rate. On the other hand, with NPUs you have less choices of quantization, for example it will be either int4 or int8 but you won’t have optimal Q4_K_M or Q5_K_M which provide great compromises of performance, memory usage and quality, which means that if Q4_0 is too bad quality for you, you’ll need to switch to Q8_0, which will effectively consume twice the memory bandwidth, hence use all that was gained by bypassing the congested busses. Thus at least it could improve the quality at the same speed.
Thanks for all the detail, really appreciate it. Really hoping we get some quality NPU libs soon so that we can see what the potential performance might actually be like (unfortunately, the Cix repos are still in pretty poor shape - and the LLM demos don’t make use of the NPU at all so far as I can tell).
In case someone is curious, here are the results of the llama.cpp benchmark on the Orion O6 board running Ubuntu 25.04, but with a discrete GPU, namely AMD Radeon RX 7900 XTX, accessed via the Vulkan API:
$ ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf
ggml_vulkan: Found 1 Vulkan devices:
ggml_vulkan: 0 = AMD Radeon RX 7900 XTX (RADV NAVI31) (radv) | uma: 0 | fp16: 1 | bf16: 0 | warp size: 64 | shared memory: 65536 | int dot: 0 | matrix cores: KHR_coopmat
| model                          |       size |     params | backend    | ngl |            test |                  t/s |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |           pp512 |      1698.22 ± 28.68 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |           tg128 |         57.64 ± 0.19 |
build: c55d53ace (6854)
llama.cpp has been built simply with:
cmake -DCMAKE_BUILD_TYPE=Release -DGGML_VULKAN=ON
P.S. I forgot the CPU-only results, though they are in line with what has already been presented here:
$ ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 8
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       8 |           pp512 |         27.44 ± 0.17 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | CPU        |       8 |           tg128 |         16.84 ± 0.05 |
llama.cpp has been built in the same way, except that -DGGML_VULKAN=ON has been omitted.
Nice! Have you checked if any CPU is saturated during the Vulkan benchmark ? I’m wondering if the CPU is just waiting for the GPU or could represent a bottleneck. Also it could be interesting to try again without the small cores which are slowing everything down usually, by prepending “taskset -c 0,5-11” then “-t 8” to llama-bench even on the first one.
I haven’t done extensive monitoring, but when running the benchmark on the GPU I don’t think that I have noticed any core going above 50% utilization. htop has a limited sampling rate, of course, so I might still be limited by a CPU bottleneck, which is strongly implied by some of the results I will mention later. Also, the Linux scheduler is doing a pretty good job of keeping the process running on the bigger cores. Anyway, I don’t understand the workload well enough to do a deeper analysis.
Here are some results:
$ taskset -c 0 ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 1
| model                          |       size |     params | backend    | ngl | threads |            test |                  t/s |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           pp512 |      1678.21 ± 19.58 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           tg128 |         62.17 ± 0.15 |
$ taskset -c 1 ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 1
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           pp512 |      1682.89 ± 16.89 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           tg128 |         62.28 ± 0.18 |
$ taskset -c 2 ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 1
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           pp512 |      1634.73 ± 10.95 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       1 |           tg128 |         47.73 ± 0.15 |
$ taskset -c "0,1,6-$((`nproc` - 1))" ./llama-bench -m Qwen_Qwen3-30B-A3B-Instruct-2507-Q4_K_M.gguf -t 8
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       8 |           pp512 |      1685.62 ± 17.42 |
| qwen3moe 30B.A3B Q4_K - Medium |  17.35 GiB |    30.53 B | Vulkan     |  99 |       8 |           tg128 |         61.92 ± 0.36 |
Note that core 1 is a Cortex-A720 one with the most recent firmware revision. So, yes, restricting the execution of the benchmark to the faster processors does have a small effect on the token generation rate, but it is not a really big deal. There is essentially no difference between the -t 1 and the -t 8 setting as long as the program runs on the Cortex-A720 cores (the process seems to start 3 threads, including the initial one). And yes, using the Cortex-A520 cores does affect the results significantly, so the CPU bottleneck might still be present on the other ones.
I also noticed that there was a set of crowd-sourced benchmark results on llama.cpp’s GitHub page, so I tried the same setup:
$ taskset -c "0,1,6-$((`nproc` - 1))" ./llama-bench -m llama-2-7b.Q4_0.gguf -ngl 100 -fa 0,1 -t 8
| model                          |       size |     params | backend    | ngl | threads | fa |            test |                  t/s |
| llama 7B Q4_0                  |   3.56 GiB |     6.74 B | Vulkan     | 100 |       8 |  0 |           pp512 |      1883.41 ± 20.67 |
| llama 7B Q4_0                  |   3.56 GiB |     6.74 B | Vulkan     | 100 |       8 |  0 |           tg128 |         99.82 ± 3.44 |
| llama 7B Q4_0                  |   3.56 GiB |     6.74 B | Vulkan     | 100 |       8 |  1 |           pp512 |      1940.74 ± 13.00 |
| llama 7B Q4_0                  |   3.56 GiB |     6.74 B | Vulkan     | 100 |       8 |  1 |           tg128 |         47.54 ± 0.04 |
My values are lower, sometimes by a lot, but we know that we probably have half of the PCIe lanes and that we lack resizable BAR support, and in addition to a potential CPU bottleneck there might be a quality of implementation issue on AArch64, given that AFAIK that platform is not supported officially by the GPU software stack (that is, best-effort support).
P.S. Actually the process uses more than 3 threads, which seems to be the steady-state value; 2 of those are spawned by Mesa 3D’s Vulkan implementation, not by llama.cpp directly. The rest seem to be short-lived worker threads that are used to load shaders (technically, started by C++'s std::future implementation).
Nice, thanks for doing them again! Your results are not far from the other ones posted there. In fact maybe you should post them there as a complement!
I didn’t know that they finally managed to reorder the CPU cores to respect the clusters a little bit better, because having the big0 cluster split across 0 and 11 was quite a pain. It’s still annoying that big cores are not contiguous but it’s making progress. And given that the little cores can be disabled in the BIOS and that this device isn’t a smartphone, it would definitely make sense to number them from 0 to 7 ordered y performance and place the little ones at the end (i.e. like on an x86 in fact).
