Mate this is not my thread… and if the owner decide its easier this way to have an understanding about widevine drm since another post from back 2020 made almost clear it works with the 32 bits version and as for the main subject to have drm working with widevine its still relevant.
Now this is not yours or mine and you are not owning nothing here. Stop saying stupid shit like:
Let's Get WideVine Working
Maybe this help a bit: https://www.da.vidbuchanan.co.uk/blog/netflix-on-asahi.html
Detailed guide but looks like glibc patch is also required.
Thanks @Damien, this is helpful. I’m going through this code to look for a way to apply to ubuntu jammy on the Rock5.
Super guide ! Really interesting to read. Thanks.
We need a patched glibc and a widevine enabled chromium.
Chromium is on the way: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia/+build/25689009
Glibc will also get uploaded to my rockchip-multimedia ppa soon.
I have made chromium pass https://bitmovin.com/demos/drm
nice
finaly something usefull and not outdated
and android is not that usefull in this, it does it diffrent as linux with widevine .
sure amazingfate can apply such thing
You almost had this killed so shut up it wasnt thanks to you moron.
hey noob , your old links are sure not usefull , and can’t you polute the rasberry community with noob answers .
and again a fantasy of yours ?, your having the bad habit to call things wich are not in the issue when you get argued .
where did i ask for a thanks ?!
i an not as you to claim things wich i didn’t do
and with or without this useless topic it was already being fixed
I would like to know where did that happened cause I usually give my references and credits.
Im not gonna keep this bs… This is pointless and you should stop dragging the forum to the mud with pointless observations as you feel pleased by disrespecting members who are trying to get help.
who is dragging what
and i only disrespect people who dont have respect like you for example.
i just made him aware why it was useless what he was doing perhaps not polite enough .
Stellar work @amazingfate!!
This is all good on the chromium-browser you compiled:
Along with vivaldi:
Note: for vivaldi, simply symlink to the chromium lib:
sudo ln -sf /usr/lib/chromium-browser/WidevineCdm/ /opt/vivaldi/
I tested a symlink to the firefox profile folder as gmp-widevine without success. I’ll update this thread when that’s working.
After update
and upgrade
, I also needed to apt install
libwidevinecdm
rockchip-multimedia-config
To document in case others encounter this, at first it wasn’t working even after a reboot, so I also uninstalled the other chromium on the system:
snap remove chromium
and reinstalled @amazingfate’s chromium:
apt reinstall chromium-browser
Testing on https://demo.castlabs.com/ was successful. Then confirmed for Amazon Video.
As noted in the ArchLinux widevine thread, the user agent has to be updated to work on Netflix. I edited my start-up shortcut to include:
--user-agent="Mozilla/5.0 (X11; CrOS aarch64 15236.80.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36"
or alternately that could be included in terminal.
For some metrics, cpu load:
@720p60 is 20-30%
@1080p60 is 30-40%
Thank you @RadxaYuntian, I had dug around many repos including android before posting this thread.
@thc013, please delete your comments above. They do nothing to add to the discourse. @DarkevilPT, please also delete your responses to thc013 in turn.
Let’s all remember, we’re here to collaborate and find solutions
For the startup, another way to include the user agent flag is to create a file:
/etc/chromium-browser/customizations/rock5b-widevine-compatible-user-agent
with contents:
set -- "--user-agent=Mozilla/5.0 (X11; CrOS armv7l 6946.63.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.75 Safari/537.36" "$@"
I did read Secure Boot on Rock 5B (and also other articles on ARM TrustZone) and I’m wondering wether widevine requires secure boot on Rock 5B.
Hi @stylon,
I’ve not been using secure boot on my 5B and widevine is working well!
Our tv is only 720p, though, so we’re not chasing FHD or 4k output.
Cheers
Hi @linuxlion,
thank you for your answer.
I did suspect already that some may run Widevine without, given that this thread contains an unexpected 0 words about secure boot which doesn’t seem straight-forward to set up. However, this still surprises me as I thought DRM cryptography must be executed in ARMs TrustZone. Unless the HDMI interface gets configured for HDCP, I doubt that Widevine uses DRM at all.
I smell that maybe only content >720p is protected by DRM these days?
Best,
stylon
This package works great on Arch Linux and widevine works even at 1080p via chromium.
Hi @stylon,
I tested a variety of platforms (including Netflix, Amazon Video, YoutubeTV). DRM content would not play regardless of quality until installing @amazingfate’s updated packages.
It does appear the streaming services above and test site previously linked indicate FHD drm is working without secure boot: https://demo.castlabs.com/
If you’re running a 4k tv/monitor, please install and report back with your DRM resolution results?
Much appreciated
To follow-up on this, it looks like libwidevinecdm
is no longer working and causing Chromium and Vivaldi to seg fault then core dump. Looking into alternate arm64 versions to re-enable DRM for the Rock5.
The WideVineCDM available from the above package is still the same as on amd64 at version: 4.10.2557.0
For now, to resume using chromium, the libwidevinecdm
package can be removed.
I’ve been away for work, however today I reinstalled libwidevinecdm
and it DRM content is again accessible. It looks like @amazingfate updated the packaged. Thanks again for your work on this!
