Thank you very much ! Im gonna have a look into this at home. I did installed vivaldi 64bits and the method for 64 didnt worked … someone had mentioned the 32 bits is working but… I wasnt sure about that (to reinstall vivaldi into 32 bits would require arquitecture change yatta yatta yatta)…
Update: Yes I did the whole supposed tutorial on vivaldi moved files into it and still couldnt get it to update its version from 0.0.0.0.0 mostly because widevine 64 is not meant to work on vivaldi 64…so I guess u can with the widevine 32… but idk if it requires vivaldi 32 instead…
Update 2: In your explanation you are meant to run vivaldi with this:
/usr/bin/vivaldi-stable --disable-seccomp-filter-sandbox --user-agent="Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36"
Also turn on the vivaldi://flags Override software rendering
See if it works. Follow the bottom of my topic here if it helps you: https://forum.radxa.com/t/guide-openfyde-rock-5b-the-best-options/15338
