upon reading your post, iām just curious have you try to flash this image? if yes, are still facing the os still rebooting after successfully flash the image. hoping to hear your feedback soon. regards.
The issue is still there. Iāve just wasted too much time to boot an image that should just work, as it is provided by radxa itself.
For the image radxa-zero-ubuntu-focal-server-arm64-20230101-1126-mbr you have to edit extlinux.conf file in the boot partition (the first one) in the image. Open the file extlinux/extlinux.conf and then:
change devicetreedir, at the end there is a āamlogicā that should not be there
add the right fdtoverlays key for UART, so that you can have console both via hdmi and serial.
If you are on windows you can just flash the image, then windows will at least find the boot partition and let you edit the file.
This is how the extlinux.conf file should look like at the end:
debos-radxa is only minimally supported until our new image can replace it.
Current if you go to Zeroās GitHub repo or Wiki download page, they all point you to 202208 image. This is because newer images are broken. There is a reason rest of the releases are marked as āprereleaseā on GitHub, so they are hidden from normal users.
In the future, we will use one of latest prereleases as a release candidate, manually test it, and mark as release if it passes the test.
I worded it very badly. Once you flash the image to an SD card, Windows will read the SD and find 2 partitions on it. The first one is the boot partition and contains a FAT filesystem, when it shows up as a drive with a letter assigned to it (eg. E:), then you will be able to edit the extlinux.conf file and fix the issue.
understood. so for your board, you are using the sd card right? what if directly flash the nand using ether? do i still need to modify the extlinux.conf @fmiz?
by the way, how about previous ubuntu focal server image 20220801? have you test it and does this issue still persist?
sorry for asking to many question. my current os is debian buster. i want to switch to ubuntu focal but just afraid any kind of issue that will happen after flash the nand.
I do not know anything about booting from nand⦠my board does not have it. I expect you will have to edit the extlinux.conf file, the issue is not related to the boot media, as you can see from the first image in this thread the issue boils down to a wrong path used to load the devicetree (dtb) file. I do not know if you have to tweak something in the uboot configuration to make it first look the onboard nand for something to boot.
Never tested. Follow RadxaYountianās advice and use it, then update the system with apt.
Iād suggest to make a backup (maybe compressed?) of the nand device first, then experiment.
Writing this I kind of noticed that I always assume one has access to the UART peripheral, instead of just video display output⦠It helps with troubleshooting and also poking u-boot. I think Iād try to make and sd card with a minimal ārescueā system, use the right commands in u-boot to make it use an extlinux.conf file in the sd, backup the nand somewhere, then experiment⦠but I expect things not to go smoothly if the version of u-boot on the nand is old, extlinux.conf support is ārecentā. It is possible to use u-boot to boot a newer u-boot on the sd card and then boot linux on the sd. Iām sorry but itās been months since Iāve touched any of these things, I do not remember the exact details. It was fun though.
