I have once again started trying to get this board to work, thinking that new kernels might fix my issues.
But I still have the problem that I cannot boot any images that are found on the download page.
Getting errors such as
end kernel panic not syncing: stack-protector: kernel stack is corrupted in: mix_interrupt_randomness
The ONLY image that works are those found here: Files · main · hardware-enablement / Rockchip RK3588 upstream enablement efforts / debian-image-recipes · GitLab (collabora.com)
I would use those but when I try installing kubernetes I get
CONFIG_IP_NF_TARGET_REDIRECT: not set
CONFIG_NETFILTER_XT_MATCH_COMMENT: not set
I have tried erasing Rock5/install/spi - Radxa Wiki and then booting from my SD card, but it wont show up on my lan when i boot it.
Given that it works with the image from collabora it shouldn’t be the SD card (tried 2) nor the power supply? (tried over 5 different)
Is there any way to get the startup logs from the SD card?
