Hi all,
I have installed the image from https://github.com/radxa-build/radxa-cubie-a5e/tags and it is working fine from SSD, the problem is that I want to install wrireguard on it and the module isn’t there, the kernel headers are not there either.
where can I find the package with the kernel headers ?
root@cubie-a5e:/tmp# modprobe wireguard
modprobe: FATAL: Module wireguard not found in directory /lib/modules/5.15.147
Perfect, yes this image works for me as well. However, I’m experiencing some strange issues with reboot/shutdown. Based on the logs, it seems to be a kernel-related problem, and I’ve noticed two possible causes: Wi-Fi module issues and a watchdog timer 10-minute timeout.
Although the Wi-Fi was functioning normally, I tried blacklisting it just in case. No luck. I also reduced the timeout value to fit within the register range; this fixed the red error, but I still can’t reboot or shut down.
I’m not very knowledgeable in this area. Do you have any suggestions?
I have noticed the issue as well and I think the cause of this issue may be a bug within the rtw89 Linux kernel driver for the onboard Realtek RTL8852BE Wi-Fi 6 module. I haven’t tried anything but probably updating this could help resolve the issue. In case you fix it let me know, thanks.
The only related wifi kernel module I could find were
aic8800_bsp aic8800_fdrv aic8800_btlpm
blocking them didn’t help me solving the issue, so probably we should have some other issues…
@ali you are right. Looking at the dmesg I can see there are many issues with power regulators and other stuff, I think the Device Tree (DTS) would need to be upgraded for the power management IC (AXP2101/AXP2202).
For anyone reading this in the future: I tested this release (maybe ther’re newer versions with reading this comment) and it boots perfectly from NVMe without any issues. I used rsetup to write the bootloader into the SPI NOR and dd to write to the NVMe. remove the SD card and enjoy booting from NVMe.
