After waiting for several months the kit arrived. I wasn’t supprised about any printed documentation but some pictured guidlines would be helpful.
So after figuring out how to mount everything I was quite dissappointed finding out that the main housing does not have the properly cut thread in order to mount the base plate. I broke one screw and now I have to get a M2 thread drill in order to get thoses screws tightend.
After installing dietpi I desparetly tried to mount the harddrive. I use a single 2TB HDD and it is not showing up on any device list. Might there be an issue with the USB bridge?
A more step by step (even if it is quite short) written instruction how to go through the installation steps would be nice.
root@DietPi:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
root@DietPi:~# lsblk
mmcblk0 179:0 0 59.5G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 59.2G 0 part /
root@DietPi:~# systemctl status rockpi-sata.service
● rockpi-sata.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-sata.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-06-17 19:34:46 BST; 6min ago
Main PID: 274 (python3)
Tasks: 7 (limit: 4915)
Memory: 23.7M
CGroup: /system.slice/rockpi-sata.service
├─274 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─929 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─933 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
├─934 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
└─935 /usr/bin/python3 /usr/bin/rockpi-sata/main.py on
Jun 17 19:34:46 DietPi systemd[1]: Started Rockpi SATA Hat.
Jun 17 19:36:13 DietPi /main.py[935]: The sensor will take effect after reboot.
root@DietPi:~# ls /dev/sd
ls: cannot access ‘/dev/sd’: No such file or directory
Ok, I just found out, that the USB bridge connector is quite tide and I had to really force it into the USB plugs.
Now the drive manager is able to see the drives! THY
