I had my rockpi 4c with sata-penta hat working until an update clobbered the OS.
I’m having a difficult time getting libmraa onto my rockpi4c. The buster-stable has the libmraa. But the bullseye-stable does not. When I install dietpi buster from my original download, the first thing it forces is in upgrade to bullseye. The version mismatches are preventing me from activating the sata-penta hat, fan and top display.
Anyone have some ideas here? I emailed setq but no reply in 3 days.
Thanks.
Follow-up: I started with dietpi buster. Interrupted the auto update process. added the buster-testing and installed the penta hat. That confirms it’s the bullseye missing components.
rebooting goes into the upgrade process and throws errors. I can stop the auto update process, but this seems like an incorrect fix and a support issue.
Need to have a complete bullseye package that works.
I hope setq or other moderator can correct this problem.
Hi Storm_Archer, same problem on my side. At least i managed to got LCD working but only for display. Stick on LCD and FAN are not working.
I think devtree overlay is not compatible with bullseye.
Would be fine if any moderator could help on this problem.
i still cant get it working!! I have reflashed 20 times… No way to get those BEEPING GPIO pins to work - I have a Raspberry Pi python scripts running with guizero and the following GPIOzero library, and I need to get the pins working on this board instead. I know i have to use “periphery” and “libmraa”
but i cant install libmraaa
when I do the guided nano changes to the sources.list it says the public key is depreciated
and then this on install
ERROR:
root@rock-4c-plus:/etc/apt# sudo apt install libmraa
Reading package lists… Done
Building dependency tree… Done
E: Unable to locate package libmraa
