i would like to update the rockpi i am running to from armbian focal to bullseye. As i have the penta sata hat installed and i am no good for scripting and programming i have to rely on the install script, but that only works with armbian focal and as it doesn’t support bullseye i wanted to check if upgrading to bullseye will fail the system.
So far i found this post that seems to describe the same problem, but there’s no workaround or solution as far as i can see. Also there is this post but i am not really sure if that fits my problem and it is hard for me to understand it, maybe someone could give me a pointer or two?
Hmmm. Do i have to open up a new thread? I thought editing the title and post should be enough to correct the mistake?
All i am asking for is an answer to ‘How difficult is it to get the TopHat for the Penta Sata Board (LCD, button, Fan Control) to work under Armbian Bullseye’.
I would love to stay with DietPi, because after getting to know the 15% of its capabilities i use, i really like its efficiency and flexibility. But i also would like to update to bullseye because of my nextcloud installation. So, please, can you give me some pointers?
