I’m trying to add a disk for my OS (database, Zabbix server-agent, Minecraft server and all others applications) to avoid always use MicroSD. NOT FOR BOOTING like Raspbian beta’s (not my goal for now)
I’ve bought external enclosue USB-3 : POSUGEAR USB 3.0 (POSUGEAR 2.5 Inch Hard Drive Enclosure, USB 3.0 External Drive Enclosure 5Gbps for SATA HDD and SSD 2.5 Inches and 7 mm/9.5 mm, UASP&Trim Acceleration SSD Case, No Tools, USB 3.0 Cable Included - : Amazon.fr: Computers)
I’ve SSD (older) Kingston ssdNow! V serie 64Gb (+5.0V - 0.9A).
I’ve HDD (older) Seagate Pipeline HD Mini 250Gb +5V - 0.451A).
When I’m plugin enclose with SSD or HDD on USB2 port : disk is visible under Disks or FileSystem or SMART menu’s of OpenMediaVault. Disks are also visible by hdparm (-I or -B). Also visible un /dev/sd*. It’s fine.
After,in FileSystem menu, if I’m selecting MOUNT and validate all parameters, system still running but
after 20 seconds : disks no longer visible detected (hdparm or /dev/ or OMV). Only way to retrieve is to unplug/plug disk from USB ports.
I’ve tried to plug USB key : no issue. ![]()
Anyone have idea
I’m in doubt but look like issue with power (but 'm not electronic/electrical expert).
@setq you’re feedback ?
Regards.
