From what I can tell, the front of the
QUAD SATA KIT for Raspberry PI 4
Kit, is the side with the HD LED’s. And as such, the OLED display is reading out upside down. Is there a way to rotate the text 180 degrees?
Yes, you can. I will support it in the next update.
I have uploaded the new version, please reinstall it and edit the conf file via
sudo nano /etc/rockpi-sata.conf
what do you add in the conf file to rotate it?
Install the new version, edit the conf file, you’ll see.
Ok, done. Very nice documentation in the Config file! Worked like a charm.
