Today is the traditional Chinese New Year, and the Radxa team all went back to their hometowns individually to celebrate the holiday with their families and friends. On behalf of the Radxa team, I’d like to pay my respects to all the Radxa users(拜年啦). I wish you all good health and all the best in 2023, the year of rabbit.
I am happy to present ROCK 5A, the credit card size 8K Single Board Computer, a gift for the year of rabbit.
Is that near as damn it Pi4 format as prob a good idea, still not sure about having a power switch that makes it so much harder than a simpler jumper for cases though and only thing as if Pi4 it would of been easy to fit a wired switch to many of the Pi cases.
Had to think of something and thats it looks good and ordered a R3 code.
Instead of relaying on m.2 M Key to m.2 A+E Key 3rd party adapters as shown on pic, for those who need to use m.2 NVMe 2230, 2242 or 2280 Storage, would be nice if Radxa would offer an official hat like “ROCK 4x - M.2 Extension board v1.6” for Rock5A with similar functionality as 3rd party adapter.
damn, too bad. i dont want to join the raspberry pi adapter/dongle hell. should’ve done a single full sized hdmi with display through usb c as well instead. or 2 full sized hdmis. None of the rpi cases fit these boards anyways because there’s always something on the bottom of the board that prevents it, so I do not see the reason for 100% sticking to rpi 4 port selection.
What would’ve been even better is to have is that size but all ports on one side of the board, kind of like how the khadas boards do it.
and im pretty sure even though it’s the rk3588s it could’ve had 4 usb 3 ports, not just 2. A usb 2.0 header on the board would be awesome instead.
and I know 2.5gbe wouldve been possible, the nano pi r6s did it with this chip.
idk all the cpu capabilities or mixtures but this is pretty bad. Only positive is the emmc and wifi socket.
too many cut corners to consider purchasing, rock 5b isn’t much bigger but has much better value.
ideal
1 x 2.5gbe
1 x full size hdmi
1 x usb c pd/qc w/display and maskrom
4 x usb a 3
1 x m.2 2230 pcie/usb
1 x m.2 2242 pcie (sata support a major plus)
1 x emmc 5.2 socket
1 x aux audio
1 x usb 2.0 header
Only with an USB3 hub needing additional PCB space. Also you should better make yourself familiar with reality before posting such weird stuff.
RK3588S is a castrated mess compared to RK3588 or even RK3568 if it’s about I/O. And 2.5GbE NICs are PCIe attached while almost everything is pinmuxed on RK3588S:
The Rock 5A should just about squeeze into a pi-top CEED.
The Rock 3A would just squeeze into the pi-top [3] if it weren’t for a slight difference in position or size of the full size HDMI connector compared to the RPi3B+.
So if the Rock 5C follows the RPi3B+ layout and uses the same HDMI alignment/connector part as on the Waveshare CM4 to RPi3B+ adapter/carrier board then the Rock 5C would indeed just squeeze into the pi-top [3].
I’m not a motherboard or cpu engineer. I’m just sharing what I would like to see in a new SBC, not a faster raspberry pi clone. Raspberry Pi has great software support, horrible port selection/position. Instead of copying the good things about raspberry pi, this board just copies the bad things, IMO.
The rk3588s is supposed to be a cut down cheaper version of the rk3588 with the exact same cpu/gpu/npu.
Its not a new SBC as the core is exactly the same and prob maybe should of been even more minimal as the choice of cost effective A76/A55/MaliG610 and the full blown rk3588 could of had more cost difference.
Rock5a is a $30 cheaper cutdown version of a Rock5b.
Its like Raspberry in a ModelA and ModelB where the ModelA is a cutdown cheaper version of the ModelB approximately.
The bottom components are very low profile and prob would fit in most cases but its still a look alike as the gpio pin mux is likely not the same and they even put on a hardware switch than say just a jumper so a case can be easily modified with a wired switch somewhere, so yeah in reality a look-a-like Pi4 is really pointless apart from the concept that Pi fans expect it that way.
Now this is the SBC i have been waiting for. The specs are very attractive. Used radxa SBC-s before and i was very satisfied with them. I ordered one 5A cuz i want to use one
The second thought is that which Linux OS will be usable first.
Third thought: Really wonder how the hardware will perform.
I am very excited and can hardly wait to het my hands on ot
This thing is obviously designed as RPi 4B drop-in replacement hardware-wise, isn’t it? Judging by the pictures there’s only two problems:
SoC position differs. But not that much so with some copper shims or a thermal pad it should be possible to even make use of those metal RPi 4 enclosures that passively dissipate the heat out of the enclosure via a huge Aluminium block reaching down to the SoC. TBC
the position of the SD card slot on the bottom looks off by a little, not perfectly centered
And then there’s the ongoing effort by volunteers and Collabora (a software contractor in the embedded world) to support as much of the hardware as possible with ‘latest and greatest’ Linux mainline kernel. Let’s see in half a decade what has happened…
The distribution (Arch, Debian, Manjaro, Ubuntu, whatever) doesn’t matter since the only part that matters is the kernel and the accompanying libs (for e.g. graphics/video acceleration). And this is the same on every OS image that will fly around for Rock 5A (or to be more precise: for any RK3588/RK3588S device since they’re all the same software-wise) today and within the next months/years.
The Rockchip BSP is basically the Android kernel which has has most focus from Rockchip.
The RK3588/s likely due to the size of the herd and number of vendors currently offering boards it seems from previous boards it has picked up more momentum, as yeah mainlining can be a painfully slow process.
A whole rake of new submissions just went in for Linux Next and prob the only thing is Mesa haven’t really seemed to pick up on this and could be a bottleneck (MaliG610) due to some politics and rumours of a rift due to ‘gaslamping’ … dunno the full story.
Things seem to be moving faster than other previous SoCs.
Interesting board as direct rpi replacement, but 5B is just way better and not much more expensive, of course physically bigger, this was first thought.
On the other hand this board can replace rpi in my quad sata hat and probably then I can sell that rpi for about same price as they are rather high now. The only question is stability, when it will be good time to make such switch. It would be interesting upgrade, but of course same thing build on Rock5B would be far much better (and bigger).
Is m.2 slot can be used with radxa sata e card? This would add one another sata port to quad sata kit. Or maybe there is something to connect small nvme? just more storage options when wifi is not needed
Rpi 4B 8GB was originally priced as $75, Rock5A 8GB is $119 (and now for $89+$5)
Direct competitor - Cool Pi 4B 4GB is about $142 (with shipping), built in wifi6 instead of m.2. Some unknown manufacturer. For now CoolPi is rather just bad choice (and more expensive).
Same M.2 Key E slot on the board as 5B, same Naneng Combo PIPE PHY in RK3588S as in RK3588 → should work with similar DT overlay as on 5B to switch between PCIe Gen2 and SATA (device address might need to be adjusted between RK3588S and RK3588).
