We are happy to announce that Radxa CM3 is available as beta for open hardware projects developers.
Radxa CM3 is an SoM(System on Module) by Radxa based on Rockchip RK3566 SoC in a small form factor at 55mm x 40mm size, integrating CPU/PMU/DRAM/STORAGE/Wireless. Radxa CM3 offers out of box cost-effective solution for multiple purpose applications.
CM3 Highlights
Quad Cortex-A55 2GHz low power and low heat solution
ARM G52 2EE with OpenGL ES 3.2, OpenCL 2.0, Vulkan 1.1 support
Neural network acceleration engine with processing performance up to 0.8 TOPS
up to 8GB ram, 128GB eMMC
Multiple display interfaces, eDP, MIPI, HDMI with dual display support
High speed interfaces such as USB3.0/SATA/PCIe 2.0
on module WiFi 5/BT 5 support
CM3 is designed as a drop-in replacement for Raspberry Pi CM4, we have tested multiple carrier boards which are designed for the CM4 including the Raspberry Pi CM4 IO board. These carrier boards can just work with CM3 without any modifications. Additionally, CM3 has more resources such as eDP and SATA/USB3.0, we make them available on a third 100p board to board connector. The detailed comparison of CM3 vs CM4 is available:
The CM3 is now available as beta for hardware developers who are working on related projects. Developers can apply a free beta hardware from the following github repository:
Any chance commercial developers can get their hands on a beta? Don’t mind to pay for it. Is there any more information on ETA and size of the first production run?
Of course software costs, but in our case, some serial buses I2S, SPI, I2C and simple filesystems will suffice. I’ll build my own skeleton RTOS from scratch in rust and that’s that. Getting to grips with all kinds of (possibly broken) Linux drivers and all the driver layers is so much hassle these days, that I’m looking to barebones dev. I don’t need proper GUI or USB support.
I am interested in buying Radxa CM3 for our project. Where I can buy it and when it will be in stock?
I am not getting any reply from radxa support email
Are you planning to support the Turing Pi V2 as a flashing method? It should work out of the box with the turing pi v2 CM4 carrier boards, but currently it doesn’t
As far as I know, Turing Pi V2 works with Radxa NX5. We don’t have Turing Pi V2 in hands but we sent samples to their Chinese partners and NX5 boots and works on it.
So after finally receiving my Radxa CM3S, it has no OS preloaded, won’t boot in neither the WD SATA board nor the TuringPi board, can’t recognize MaskRom mode in either one, and now worse, my RPi CM3 is no longer recognized in either one. I think the Radxa CM3S ruined both boards.
Hi Wenzhe,
The samples of CM5 is ready now, and it will be in production in the next month.
And the samples of NX5 is in production now, it will also be available in the few months.
Both the WD SATA board and the TuringPi board are for RPi CM1/3. From all of what I read the Radxa CM3S was supposed to be a drop-in replacement for the RPi CM3 on its carrier boards. My intention was to use it on the WD SATA board as it neither it nor the RPi CM3 has WiFi/BT onboard where the Radxa CM3S does.
MaskROM mode (UGH)
2a. move the TuringPi jumper from boot to flash
2b. connect USB microB cable
2c. HOLD the tiny MaskROM button WHILE plugging in the TuringPi power
After it is done writing, it will reboot the Radxa CM3S, but nothing will be usable on the TuringPi until the jumper is moved back from flash to boot and restarted.
