IMX577 on Rock 5
Today i received an IMX577 camera sensor that i had planned to interface it with Rock 5 (B/C).
I was preparing myself for the torture of getting something out of the sensor, based on the information that there is some compatibility with IMX477. Also, there appears to be a Rockchip driver in the kernel tree, so that might help.
The problem is the vendor announced it as a camera module for Raspberry Pi 4, 15 PIN but the FPC cable is 0.5mm pitch (or 0.3mm, not sure), so i need an adapter.
Does anyone know if there is an FPC adapter, 15P 0.5mm pitch to 1.0 mm pitch?
@radxa team, any chance we will see an imx577 camera module with CS mounting bracket for the Rock 5 series?
We heard your voice :slight_smile: Let’s just make it. We have a new platform upcoming, which we will support the imx577 by default. It’s time to customize a imx577 sensor.
You can use this adapter cable to use the RPi 15pin camera on Radxa 31pin CSI:
https://radxa.com/products/accessories/fpc-cable-008/
Hi Jack,
It’s great to hear about the imx577 support. Let me know when you have a prototype.
Regarding the adapter, it is impossible to use the 15P FPC cable, let’s wait for the Radxa solution.
But for IMX477, yes, it works great.
