So, I made an RPI-imager repository to make it easier to find and flash images built for the Radxa Rock 5 Series.
To use this repository, just install rpi-imager and start it by:
rpi-imager --repo https://rock5-images-repo.github.io
Radxa Imager is a customized version of
rpi-imager I made just for fun. The normal version of rpi-imager with the --repo command will get you all the images.
Known issues: when you flash an image, rpi-imager may show writing and go beyond 100%, (if you see writing 2999% it is normal, don’t worry it will work, just be patient) because most images have not been updated to actual file size, so just ignore that and be patient, it should show verifying once it is done writing.
Notes: PRs are welcome to help us get all the images there.
@DarkevilPT and I will help get them updated soon.
