Good day, friends!
I try to use PWM for my LED to be able to provide a pulsating/dimming effect (from bright to dim and back). For that I’m wanted to use sysfs to achieve this. Sysfs is currently working with GPIO pins.
Using the latest DietPi OS, I enabled the device tree overlay for PWM in /boot/dietpiEnv.txt by adding the line user_overlays=dietpi-usb-otg meson-g12a-pwm-c-on-gpiox-8 meson-g12a-pwmao-a-on-gpioao-11. After reboot I can confirm that two new chips were detected by sysfs with the command cat /sys/kernel/debug/pwm
root@DietPi:/boot# cat /sys/kernel/debug/pwm
# PWMAO
platform/ffd1a000.pwm, 2 PWM devices
pwm-0 (sysfs ): requested enabled period: 1000000 ns duty: 900000 ns polarity: inverse
pwm-1 (sysfs ): requested enabled period: 1000000 ns duty: 900000 ns polarity: inverse
# Always here, assume wifi modulation
platform/ffd19000.pwm, 2 PWM devices
pwm-0 (wifi32k ): requested enabled period: 30518 ns duty: 15259 ns polarity: normal
pwm-1 (sysfs ): requested enabled period: 100000 ns duty: 90000 ns polarity: normal
# PWM
platform/ff807000.pwm, 2 PWM devices
pwm-0 ((null) ): period: 0 ns duty: 0 ns polarity: normal
pwm-1 ((null) ): period: 0 ns duty: 0 ns polarity: normal
# Always here, assume cpu overclocking
platform/ff802000.pwm, 2 PWM devices
pwm-1 (regulator-vddcpu ): requested enabled period: 1250 ns duty: 175 ns polarity: normal
Another output pwmchip4 -> PWM and pwmchip6->PWMAO
root@DietPi:/boot# ls /sys/class/pwm/
pwmchip0 pwmchip2 pwmchip4 pwmchip6
I aim to activate the LED that is connected to PIN_40 (GPIOAO_11, PWMAO_A) and ground. For now I assume that pwmchip6 is controlling PWMAO. Because that chip appeared after I added meson-g12a-pwmao-a-on-gpioao-11 in dietpiEnv.txt.
Configuring both available channels result in no change. LED is not enabled.
# Enable channels
echo 0 > /sys/class/pwm/pwmchip6/export
echo 1 > /sys/class/pwm/pwmchip6/export
echo 1000000 > /sys/class/pwm/pwmchip6/pwm0/period
echo 900000 > /sys/class/pwm/pwmchip6/pwm0/duty_cycle
echo 1 > /sys/class/pwm/pwmchip6/pwm0/enable
echo 1000000 > /sys/class/pwm/pwmchip6/pwm1/period
echo 900000 > /sys/class/pwm/pwmchip6/pwm1/duty_cycle
echo 1 > /sys/class/pwm/pwmchip6/pwm1/enable
echo normal > /sys/class/pwm/pwmchip6/pwm1/polarity
echo normal > /sys/class/pwm/pwmchip6/pwm0/polarity
Test GPIO PIN_40. This enables the LED and its very dim.
export gpio=423
echo $gpio > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio${gpio}/direction
echo 1 > /sys/class/gpio/gpio${gpio}/value
How it is usually done? Have you some examples? I activated every channel on both chips and connected the LED to every PIN where PWM is labeled.
Sysfs is mandatory since the application will be written in nodejs using some npm wrapper packages around sysfs
Thanks in advance!
