[SOLVED] Zero 3E PWM GPIO under Kernel 6.1 Ubuntu
My Host
OS: Armbian (24.8.4) aarch64
Host: Radxa ZERO 3
Kernel: 6.1.75-vendor-rk35xx
Uptime: 1 hour, 27 mins
Packages: 1011 (dpkg)
Shell: bash 5.2.21
Terminal: /dev/pts/1
CPU: (4) @ 2.000GHz
Memory: 1313MiB / 3732MiB
Overlays I have activated (as per github & .dts contents these are for Zero 3)
overlays=npu-enable pwm12-m1 pwm13-m1 pwm14-m0 pwm14-m1 pwm15-m1 pwm8-m0 pwm9-m0
After this I can find
ls /sys/class/pwm/
pwmchip0  pwmchip1  pwmchip2  pwmchip3  pwmchip4  pwmchip5
cat /sys/class/pwm/pwmchip{0,1,2,3,4,5}/device/modalias
of:NpwmT(null)Crockchip,rk3568-pwmCrockchip,rk3328-pwm
However, there is something wrong
cat /sys/kernel/debug/pwm
platform/fe700030.pwm, 1 PWM device
 pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
platform/fe700020.pwm, 1 PWM device
platform/fe700010.pwm, 1 PWM device
platform/fe700000.pwm, 1 PWM device
platform/fe6f0010.pwm, 1 PWM device
platform/fe6f0000.pwm, 1 PWM device
The output should be something like How to use any PWM on Radxa Zero (sysfs)
I have also compiled mraa However per official documentation it will not work under kernel 6.1 https://docs.radxa.com/en/zero/zero3/app-development/mraa#pwm
I can run CLI commands properly though
mraa-gpio list
01         3V3:
02          5V:
03    GPIO0_D1: I2C  UART
04          5V:
05    GPIO0_D0: I2C  UART
06         GND:
07    GPIO3_C4: GPIO PWM
08    GPIO0_D1: UART
09         GND:
10    GPIO0_D0: UART
11    GPIO3_A1: GPIO
12    GPIO3_A3: GPIO
13    GPIO3_A2: GPIO
14         GND:
15   GPIO03_B0: GPIO
16   GPIO03_B1: GPIO PWM  UART
17         3V3:
18    GPIO3_B2: GPIO PWM  UART
19    GPIO4_C3: GPIO SPI
20         GND:
21    GPIO4_C5: GPIO SPI  PWM  UART
22    GPIO3_C1: GPIO
23    GPIO4_C2: GPIO SPI  PWM
24    GPIO4_C6: GPIO SPI  PWM  UART
25         GND:
26    GPIO4_D1: GPIO
27    GPIO4_B2: GPIO I2C
28    GPIO4_B3: GPIO I2C
29    GPIO3_B3: GPIO
30         GND:
31    GPIO3_B4: GPIO
32    GPIO3_C2: GPIO UART
33    GPIO3_C3: GPIO UART
34         GND:
35    GPIO3_A4: GPIO
36    GPIO3_A7: GPIO
37    GPIO1_A4:
38    GPIO3_A6: GPIO
39         GND:
40    GPIO3_A5: GPIO
mraa-gpio version
Version v2.2.0 on Radxa ZERO 3
Any help will be highly welcomed
In examples folder of mraa I tried both pwm.c & pwm.py both gave this error
Error initialising PWM on pin
I did change PIN# for instance in python code
import mraa
import time
# initialise PWM
x = mraa.Pwm(23) #in my case it will be 7,23,24...
# set PWM period
x.period_us(700)
# enable PWM
x.enable(True)
value= 0.0
while True:
    # write PWM value
    x.write(value)
    time.sleep(0.05)
    value = value + 0.01
    if value >= 1:
        value = 0.0
Nothing wrong with your output, you need to export it and set the values.
I’m not running kernel 6.1.x on my 3W, but I’m running 6.1.x in Rock5-lite, where you can use the PWM pins the same way. Take this as an example:
root@rock5c-lite:/home/rock# cat /sys/class/pwm/pwmchip{0,1,2,3,4}/device/modalias
of:NpwmT(null)Crockchip,rk3588-pwmCrockchip,rk3328-pwm
root@rock5c-lite:/home/rock# cat /sys/kernel/debug/pwm
platform/febd0030.pwm, 1 PWM device
platform/febd0020.pwm, 1 PWM device
platform/fd8b0030.pwm, 1 PWM device
 pwm-0   (pwm-fan             ): requested enabled period: 60000 ns duty: 59999 ns polarity: normal
platform/fd8b0010.pwm, 1 PWM device
platform/fd8b0000.pwm, 1 PWM device
root@rock5c-lite:/home/rock# echo 0 > /sys/class/pwm/pwmchip1/export
 pwm-0   (sysfs               ): requested period: 0 ns duty: 0 ns polarity: inverse
T
Due to changes in the pwmchip driver, the PWM function of the MRAA does not work properly on the 6.1 kernel.
The current pwm driver assigns the pwm chip id dynamically, rather than statically as in the past.
Hey @ioncube I know it’s not related to your question, but how are you running your board at 2.0Ghz under Armbian?
@avaf @Nasca
python-periphery works instead of mraa
Thanks for your input. I have been successful in running PWM under Kernel 6.1
Instructions are here:
https://www.reddit.com/r/OrangePI/comments/1jl963x/success_activating_using_pwm_on_opi_3b_radxa_3e/
My github account which had a wealth of knowledge is being suspended temporarily. I am resolving it at the moment. You can overclock both CPU & GPU
I am attaching overclock .dtb & .dts In my configuration only CPU is overclocked
rk3566-radxa-zero3.zip (62.4 KB)
Thank you for sharing.
