How to upgrade F/W with jms561 under Raspberry Pi
Ok.
think I found a pretty solid solution. I’ve thought that before so I might update when something goes wrong again…
I’m using the hardware raid feature of the quad sata board’s jmicron controllers. See link in above post on how to do this.
Together with zfs.
My first setup failed:
Two disks on controller 1 in RAID1
Two disks on controller 2 in RAID1
zpool create -f tank /dev/sda1 /dev/sdb1 (no mirror)
This way I dont write to the two controllers at the same time all the time.
But this failed after ~45min (disk disconnects)
My second setup seems to hold up:
Two disks on controller 1 in JBOD
Two disks on controller 2 in JBOD
zpool create tank mirror /dev/sda1 /dev/sdb1
So now I’m letting zfs do the mirroring. And the controllers dont have to write to two disks per controller at the same time. My thinking is. This makes it as easy as possible for the jmicron controllers (and their problems)
I have now rsynced 500G to that zpool over the course of a few hours. No disconnects yet.
edit: 8hours later and 1,4TB later. Still all good. No disconnects. This could be a winning setup
Mine is working stable for about year now. I’m using ext4 + RAID 1 on both controllers. It also worked fine with UAS disabled and with no particular SMART queries, but this was very problematic on OMV when each update needed to fix code. Also hardware RAID don’t use CPU that much.
Hi Thomas,
the latest version (v8.1.3.6) is a complete disaster for me with disconnecting disks, deleted partitions, corrupt GPT/MBR tables, deleted software-raid-configuration.
Is it possible for you to send me the firmwareversion of v8.0.3.4 as it sounds way more promising (and it can’t be worse than this version).
Thanks in advance!
Gr. TCH
