I recently recieved the quad SATA-kit and I’m having problems with accessing/using the drives.
I installed the software using “curl -sL https://rock.sh/get-rockpi-sata | sudo -E bash -” according to https://wiki.radxa.com/Dual_Quad_SATA_HAT. When I install the software or start my rpi all the LEDs light up but then they turn off again. If I restart the rockpi service they light up but go black again.The OLED and fan on the top never start from what I can see.
If I use “systemctl status rockpi-sata.service” I can see the drives but I cant access them.
Since the drives show up and the LED’s turn blue everytime i restart the software it doesn’t feel like its a problem with the connection but I will try that when I get home just to be certain.
I have now tried to dissasemble everything and then reasemble it but I still have the same problem.
Currently I’ve tried to boot with the following just to make sure it wasn’t my Power Supply that gave to little power:
4 2.5" HDD’s
1 2.5" HDD
1 2.5" SSD
2 2.5" SSD’s
But I always get the same problem.. The software “kind of” find the drives but I cant do anything with them. How did you do your software raid?
Which OS do you use?
Note: the top fan/LED doesn’t seem to work either.
I reinstalled it and now I can access the drives!
Thank you for fixing it
Do you know what kind of cable it is? (Might find it in a store here since its quite the transport to Europe)
Or who do I contact for the cable and some new screws since the one attaching the Sata-hat to the rpi4 where to big?
Unfortunately I could not find any reseller of the cables thtat could sell less than 100 unless it was from China. Also having issues that the USB-C cable I bought doesn’t work through the chassi because its to thick. I assume I should contact Allnet China about it?
You can buy the connector shells at Digi-Key, and wires with the terminals already crimped on the ends there as well.
The connector housing is part PHDR-10VS, and they are $0.35 each, the wires are 6" long and part number APAPA22K152, and are about $0.40 each.
