I’m currently using Rock4SE.
I have confirmed that the port can be turned on/off using the following method.
1)Move directory
cd /sys/class/gpio/
2)Create a file for the GPIO
sudo sh -c “echo 154 > export”
3) Specify as input port
sudo sh -c “echo in > gpio154/direction”
4) Pull up
sudo sh -c “echo ‘high’ > gpio154/direction”
5) Check port status
cat gpio154/value
However, even if I check the port switching using the source code below, it does not turn ON/OFF.
What’s wrong?
I think mraa is functioning because it displays the I/O list and the mraa version.
Perhaps this pull-up setting is not working, right?
Looking at the mraa source code, it doesn’t seem to be working.
(Intel’s edison seems to support programmatic pull-ups, but no other boards seem to support it.)
Does this mean that the only solution to this problem is to wire a pull-up resistor?
@WATANABE i am newbie to rock4se project board. i am operating debian 11 bullseye on it.
i am unable to install mraa for debian. however i have installed mraa python 3 binding, can you please guide me how can i install mraa for debian.
i am also trying to read gpio pins using mraa.
