Hello, I first got an top hat that overheated when i turned it on for the first time and smoked and since then just received a replacement board.
I have connected the new replacement top hat and it does not overheat or anything however it does also not work.
When i have the top board unplugged I can see 51 when executing the command sudo i2cdetect -y 1
But when i connect the top board i dont see anything on the output of the command.
Im using an RPI4 and have tried different OSs and i am currently using raspberry pi OS.
Any help would be appreciated, Thanks.
I can not find a cable locally could you guys send me a new one to test?
I do not know what the error is currently with the board but the problem still exists. Maybe the main board needs to be replaced?
