[Guide] openFydeOS - Rock 5B - the best option 🍺
Hi, oh that Info went above my head ( most of it i could understand eventhough).
I want to share my experience here now. i flashed using RPi Imager onto NVME and after that put my RK3588 into MaskROM Mode and flashed SPInor bin and image after that my Board booted straight into Fyde OS.
i used Openfyde while i didnt find Fyde OS for RK3588(Rock 5b+ to be more specifically). if you could find a specific image for 5b+ pls. suggest me.
I even found Android Subsystem and i am right now in the process of activating it… when it succeeds i will write here… i am trying to explore Openfyde OS now.
But in the initial Experience it is much snappier and responsive compared to Android 12 image on my 5b+. let see how far this Fyde OS fulfill my needs… thanks for your time…
There wont be one. FydeOS isnt expanding their branch of sbcs at the moment. All you can do is… try the rock 5b one
Any problem with wifi?
I can’t enable it on my newly installed FydeOS 20. I have the wifi module from Radxa, how can I install the drivers?
Grab an Wifi N type of usb with Antenna. Its the only one that works for me. They keep changing kernel each version (or maybe its just armbian on the background) that only supports N for now.
