I’ve been playing with gstreamer this weekend and with latest CLI image your pipe example worked fine:
gst-launch-1.0 videotestsrc is-live=true num-buffers=600 ! video/x-raw,width=1920,height=1080,framerate=30/1,format=YUY2 ! videoconvert ! video/x-raw,format=YV12 ! omxh264videoenc ! filesink location=test.mp4
Problem is with NV12, it can encode but i think omxh264videoenc expects YV12 format.
And videoconvert most likely doing a software conversion.
Note:
I attached a USB webcam, v4l2src failed with:
0:00:00.146889825 697 0xaaaaf2db2e00 DEBUG v4l2 v4l2_calls.c:529:gst_v4l2_open:v4l2src0:src Trying to open device /dev/video2
0:00:00.146907535 697 0xaaaaf2db2e00 INFO v4l2 v4l2_calls.c:540:gst_v4l2_open:v4l2src0:src enable aw isp!
0:00:00.146918619 697 0xaaaaf2db2e00 INFO v4l2 v4l2_calls.c:560:gst_v4l2_open:v4l2src0:src Get device id = 2
0:00:00.146997835 697 0xaaaaf2db2e00 INFO v4l2 v4l2_calls.c:577:gst_v4l2_open:v4l2src0:src —VIDIOC_SET_DMA_MERGE[1] start—
0:00:00.147009878 697 0xaaaaf2db2e00 ERROR v4l2 v4l2_calls.c:579:gst_v4l2_open:v4l2src0:src VIDIOC_SET_DMA_MERGE error!
- maybe not enough cma reserved memory!
Update 2:
yeah, that was cma issue, but now libisp crashed with uvcvideo driver, so csi camera depends on libisp to work properly and libisp crash with uvcdriver. We can only hope radxa engage with allwinner to fix this or get some workaround.
0:00:00.285649011 572 0xaaaad428b800 DEBUG v4l2bufferpool gstv4l2bufferpool.c:1534:gst_v4l2_buffer_pool_release_buffer:v4l2src0:pool0:src release buffer 0xaaaad42c6a20
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP602
branch: libisp-dev
commit: 665dc2e9613716c25abb6b64af145a73b989271e
date : Wed Dec 18 15:26:13 2024 +0800
author: [email protected]
[ISP]video device name is vin_video2
[ISP_ERR]isp_get_isp_id, line: 217,can not get entity by name vin_video2
[AWIspApi]: F:awIspGetIspId, L:104, video2 → isp-2
Caught SIGSEGV
exec gdb failed: No such file or directory
Spinning. Please run ‘gdb gst-launch-1.0 572’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:11.663424634
I don’t think the frame from uvcdriver should pass through libisp:
IPCORE: ISP602
branch: libisp-dev
Thread 4 “v4l2src0:src” received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xfffff4c101b0 (LWP 832)]
0x0000fffff624f0c4 in isp_set_stitch_mode ()
from /usr/lib/aarch64-linux-gnu/libisp.so
(gdb) st
Ambiguous command “st”: stack, start, starti, status, step, stepi, stepping, stop, strace.
(gdb) bt
#0 0x0000fffff624f0c4 in isp_set_stitch_mode ()
at /usr/lib/aarch64-linux-gnu/libisp.so
#1 0x0000fffff67160b8 in () at /usr/lib/aarch64-linux-gnu/libAWIspApi.so
#2 0x0000fffff68dfe00 in ()
at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so
#3 0x0000fffff68e0644 in ()
#4 0x0000fffff7ea1e90 in gst_buffer_pool_set_active ()
at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#5 0x0000fffff68e55f4 in ()
#6 0x0000fffff6875734 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#7 0x0000fffff6879098 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#8 0x0000fffff7f1a11c in ()
#9 0x0000fffff7d8b438 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#10 0x0000fffff7d8a964 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#11 0x0000fffff7c76648 in start_thread (arg=0xfffff4c0fab0)
at pthread_create.c:477
#12 0x0000fffff7bccd5c in thread_start ()
at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
My last attempt:
gstreamer requires setting en-awisp=0 to avoid passing the frame to libawisp (i have imx-214 and usb camera attached), but then I run into a wall: there is no way to force v4l2src to use a format other than NV12 (maybe is the proprietary nv12 format?), and I get the following error:
0:00:03.206974784 2374 0xaaaac48054d0 DEBUG v4l2 v4l2_calls.c:529:gst_v4l2_open:v4l2src0:src Trying to open device /dev/video0
0:00:03.207007368 2374 0xaaaac48054d0 INFO v4l2 v4l2_calls.c:560:gst_v4l2_open:v4l2src0:src Get device id = 0
0:00:03.207151829 2374 0xaaaac48054d0 INFO v4l2 v4l2_calls.c:584:gst_v4l2_open:v4l2src0:src —VIDIOC_S_INPUT[0] start—
0:00:03.207190580 2374 0xaaaac48054d0 INFO v4l2 v4l2_calls.c:598:gst_v4l2_open:v4l2src0:src —VIDIOC_S_PARM[0] start—
0:00:03.207221705 2374 0xaaaac48054d0 ERROR v4l2 v4l2_calls.c:600:gst_v4l2_open:v4l2src0:src VIDIOC_S_PARM error!
I tried to update to latest radxa-allwinner deb packages but run into dependencies hell.
