I’m trying to set up an image for Talos Linux. It’s got its own pretty opinionated & minimalist image generator that assumes a GRUB EFI boot, and I cannot practically use something like extlinux.conf instead (believe me, I went pretty far down this road
For slightly more context, I re-compiled radxa/u-boot with EFI support by adding the following to ./u-boot/configs/rock-5b-rk3588_defconfig:
CONFIG_CMD_BOOTEFI=y
CONFIG_EFI_LOADER=y
This is all working, and I can get to a GRUB shell that was loaded via the EFI and has access to the root partition.
As soon as I try to actually boot the kernel, however, I’m getting a Data abort exception.
Here’s the full log:
Booting `A - Talos v1.2.0-alpha.2-32-gfaf92ce01-dirty'
EFI stub: Booting Linux Kernel...
EFI stub: ERROR: FIRMWARE BUG: efi_loaded_image_t::image_base has bogus value
EFI stub: ERROR: FIRMWARE BUG: kernel image not aligned on 64k boundary
EFI stub: ERROR: Could not determine UEFI Secure Boot status.
EFI stub: Using DTB from configuration table
EFI stub: ERROR: Failed to install memreserve config table!
EFI stub: Exiting boot services and installing virtual address map...
"Synchronous Abort" handler, esr 0x96000010
* Reason: Exception from a Data abort, from current exception level
* PC = 00000000002044d0
* LR = 00000000002044cc
* SP = 00000000eb9f6d60
* ESR_EL2 = 0000000096000010
* Reloc Off = 00000000edb66000
x0 : 0000000000400000 x1 : 0000000000000000
x2 : 0000000000000000 x3 : 00000000ebd6daea
x4 : 0000000000000000 x5 : 0000000000000010
x6 : 0000000000000000 x7 : 00000000ede2d704
x8 : 0000000000000008 x9 : 0000000000000003
x10: 0000000000000044 x11: fffffffffffffffd
x12: 0000000000000000 x13: 00000000eb9f6ec8
x14: 00000000a7d10000 x15: 00000000eb9f6e6c
x16: 00000000ea9c2030 x17: 0000000000000005
x18: 00000000eb9ffce0 x19: 0000000000400000
x20: 0000000000000000 x21: 00000000ab3a9000
x22: 00000000ebd85d80 x23: 00000000ab2c0a64
x24: 00000000eb9f7058 x25: 00000000ebd85d80
x26: 00000000ab3a9000 x27: ffffffffffffffff
x28: 00000000ab3a1161 x29: 00000000eb9f6f40
Call trace:
PC: [< 002044d0 >]
LR: [< 002044cc >]
Stack:
[< 002044d0 >]
[< 00289454 >]
[< ffffffffbd76067c >]
[< ffffffffbd75afec >]
[< ffffffffbd75a858 >]
[< 002899a8 >]
[< fffffffffcdc2dfc >]
[< fffffffffce4558c >]
[< fffffffffcca0c24 >]
[< fffffffffcca07a8 >]
[< fffffffffcc9cc20 >]
[< fffffffffcc9d054 >]
[< fffffffffcc9d130 >]
[< fffffffffccaa404 >]
[< fffffffffcca9018 >]
[< fffffffffcca9e94 >]
[< fffffffffcca827c >]
[< fffffffffcc9cf50 >]
[< fffffffffcca083c >]
[< fffffffffce671f0 >]
[< fffffffffce673f8 >]
[< fffffffffce64e20 >]
[< 00209088 >]
[< 002093dc >]
[< 00209460 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218630 >]
[< 00217d80 >]
[< 00218334 >]
[< 00218110 >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218110 >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218110 >]
[< 00218110 >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218110 >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218630 >]
[< 00217d80 >]
[< 00218334 >]
[< 00218110 >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a654 >]
[< 0022b08c >]
[< 0021847c >]
[< 00218630 >]
[< 00217d44 >]
[< 0022a5b8 >]
[< 00218cd0 >]
[< 00216b58 >]
[< 0021934c >]
[< 0028fcf8 >]
[< 002195c4 >]
[< 00201e18 >]
Copy info from "Call trace..." to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU ...
### ERROR ### Please RESET the board ###
I didn’t get anywhere with stacktrace.sh from radxa/u-boot, unfortunately. It didn’t symbolicate anything - I did tell it to use the same gcc toolchain from radxa/toolchain that I used for the build because it was looking for one that didn’t exist but not sure if that was really the problem.
I’m using the kernel & DTB from the most recent Debian Bullseye release (rock-5b-debian-bullseye-xfce4-arm64-20221118-1736-gpt.img).
I’ve also tried a locally-compiled kernels/DTB (both linux-5.10-gen-rkr3.4 & stable-5.10-rock5) with the same result.
I tried looking at an Armbian EFI image for the Station M3 (an RK3588S-based board), specifically Armbian_22.11.0-trunk_Station-m3_jammy_legacy_5.10.66.img. I didn’t see any special clues there - its setup looks virtually identical to mine.
I’m not getting any Linux kernel output before the “Synchronous Abort” handler kicks in. I only have a single USB-TTL cable so can’t use earlycon but I’m skeptical it’d yield too much more either.
Does anyone have more experience or advice here?
