FydeOS for 5b runs on ROCK 5A after replacing dtb
Currently fydeOS for you haven’t officially support ROCK 5A.
However, by replacing the /boot/dtbs/rockchip/rk3588-rock-5b.dtb with rk3588s-rock-5a.dtb, it runs well on ROCK 5A as an early preview XD
Amazing !! Im still waiting on the micro hdmi cable ! I didnt had one
The file u mentioned is already in the folder. Why or how does it needs to be replaced??
I simply renamed the 5a one to 5b lol
I just did that on the MicroSD but it doesnt boots up idk if its because its on the MicroSD and need be on the EMMC or maybe nvme but No luck :1
I did sudo nautilus renamed them and rebooted no blue light just green.
Yeah it needs to be on emmc to boot, which was the same when I did the test
However, you can still boot it off tf card if you hook up the uart console and interrupt the u-boot, use mmc dev X(X is the number for sdhci) and then run mmc_boot
Hi!
Can’t find this path: /boot/dtbs/rockchip/rk3588-rock-5b.dtb with rk3588s-rock-5a.dtb
Where you replacing dtb file? In original image\At uSD card\eMMC?
eMMC in ‘ROOT-A/boot/rockchip’ has .dtb collection with rk3588s-rock-5a.dtb file
Yeah and apparently if you use that rock-5b and rename to that one you should be able to boot it.
I tried that and didnt worked for me… If you do it… let me know.
Use sudo nautilus u will find the path select show hidden files etc.
