I am trying to flash the eMMC on my brand new Radxa Zero 3W, but have failed so far.
I have installed and compiled rkdeveloptool following instructions from Radxa [1].
Hey @langweiler I’m trying to follow your instructions with my Radxa Zero 3E, but I get " No space left on device" what image are you writing to the EMMC?
Are you sure the Radxa Zero 3E is equipped with eMMC? I believe I read somewhere that it does not come with eMMC. I am using a Zero 3W with 2 GB of eMMC. The eMMC needs to be explicitly selected as option when buying the device.
any idea how to erase the emmc and bring back to factory setting? doing this more to learn about the device, but haven’t been able to figure out how to erase the Emma on this.
As I read conflicting things about the Zero3W, I get the “inference” that in order to boot onto eMMC, you need a minimum device of 2GB Ram and 16 GM of eMMC. Is that correct? I don’t remember that being mentioned anywhere in the sales documentation when I made my purchase of (2) Zero 3W: 1GB ram & 8GB of eMMC.
Additional advice: If you use the Radxa Zero 3W together with Armbian, you can use the armbian-config tool to transfer your image from an SD card to the onboard eMMC. The tool does all the required magic for you. Very convenient.
Extra tip for headless install of image to eMMC where you first edit the WiFi and other parameters.
Using DietPI image in this example
download image -> extract so you get the native .img file
check partitions that exist in the image using fdisk
sudo fdisk -l DietPi_RadxaZERO3-ARMv8-Bookworm.img
Disk DietPi_RadxaZERO3-ARMv8-Bookworm.img: 1.13 GiB, 1207976448 bytes, 2359329 sectors
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: gpt
Disk identifier: 77E56261-4023-4345-91AC-EE144546C393
Device Start End Sectors Size Type
DietPi_RadxaZERO3-ARMv8-Bookworm.img1 32768 2357247 2324480 1.1G Linux filesystem
DietPi_RadxaZERO3-ARMv8-Bookworm.img2 2357248 2359295 2048 1M Microsoft basic data
in this case, 2 partitions exist and the DietPI filesystem resides in the first partition.
We can mount this partition and make changes because there is “free space” in the partition.
to mount we need to calculate the offset of partition by multiplying the start sector (32768) with the sector size (512) = 16777216
use that to mount in Read-Write mode to a mountpoint of your choice (make sure that folder exists first, in this case /mnt/img)
sudo mount -o loop,rw,sync,offset=16777216 DietPi_RadxaZERO3-ARMv8-Bookworm.img /mnt/img
now you can change
/mnt/img/boot/dietpi-wifi.txt for the wireless SSID and password
/mnt/img/boot/dietpi.txt for root password, locale, keyboard, WiFi country code, Timezone
more settings in the DietPi manual but these basic ones are enough
