Hi! I want to download FEX on my ROCK 4 SE, but the PPA does not work. See attached image. How should I solve this?
Thanks in advance!
Thanks in advance!
I have tried with
sudo add-apt-repository ppa:fex-emu/fex
sudo apt update
If you had googled “rock 4 se public key not available” then the first result would have been this thread that contains the solution to fix that error -> Sudo apt update get error
export DISTRO=focal-stable
wget -O - `apt.radxa.com/$DISTRO/public.key` | sudo apt-key add -
apt update should work fine after those commands.
I have abosolutely no idea about FEX beyond that. This just gets apt update not moaning.
@mathew Yes, have written those lines earlier which solved my problem. now i am struggling with the RootFS.
