I want to enable PoE oh my rock 5b but without the use of a hat.
I’m looking at this page: https://wiki.radxa.com/Rock5/hardware/5b and it shows pins 2 and 4 for PoE.
I don’t quite understand the importance of that in relation to PoE. What do i nees to do with those pins?
You can’t enable PoE without a PoE hat of some form. All the Rock5 does is break out the 48v power that is delivered over the Ethernet cable onto the 4 pins near the Ethernet jack. Something (the PoE hat) needs to convert that to 5v to power the Rock5 - which the Hat delivers on pins 2&4 of the grid header.
You won’t find one. You could use 2 ethernet cables (1 for the POE split and 1 for data) or create a cable from the poe pins to the poe power board.
2.5Gbe POE is too new and most deployments would just use 2.5Gbe injectors for any Acces Point that might require it. The Rock5b is the only device I know of that would need such a thing.
I have indeed a rockpi5b and a poe hat ROCK Pi 23W PoE HAT found in :https://wiki.radxa.com/ROCKPI_23W_PoE_HAT. However it doesn’t mechanically fit onto the rockpi 5b board .
so could you please explain how did you manage to use it with a rockpi 5b ?
Actually it does fit on, but you need a different fan which I’ve also tested and got working, but the main concern was the fan position as it doesn’t sit directly above the CPU.
Since then I contacted Radxa and they have informed me that they are indeed making a PoE hat specifically for the rock 5 which will be available in April.
I purchased a different fan and soldered on a Micro JST 1.25mm 2-Pin Connector which is the mechanical presentation on the board, but it’s pointless due to the position of the fan
