eMMC don’t require anything in SPI and it should just boot with correctly burned image,
I guess that it was just not flashed correctly.
Hello everybody. Few days ago i bought “USB3 eMMC Reader” with GL3227E and after use this with emmc module I’m dissapointed. It is true - reader can read and write faster , but when I put it to usb slot I have to wait too longer … Dmesg gives me many I/O errors, GL chip is very, very hot and when I try to start my OS ( debain, slackware or WIN7) the boot computer is freeze. I can’t boot any OS from this redaer - moreover when I use cheaper emmc <—>microSD adapter whit the same module everything is correct. The most irritation for me is impossibility to use only main pinout ( GND, VDD, CLK, CMD and DAT0 ) to read in 1 bit mode … Wasted time and money …
Most of such software can also verify burned image, have You done that?
There should be no difference with cheap/slow adapter and fast based on GL3227E, checksums will tell You truth.
Yes I know it. But it is not the point - even whitout module dmesg command gives me lot of errors . maybe firmware should be upgraded … Maybe I had immproper emmc module - but why the device can’t read in one bit mode ? In database genesys logic there is information about that . Maybe this is a question for hardware engineers
Does any one know if radxa has an eMMC adapter (MicroSD or USB) for an Orange Pi eMMC board; http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-emmc.html
– Wink
It’s same eMMCs as those used in all radxa boards and yes, Radxa has both eMMC to micro SD as well as usb3.1 eMMC adapter:
First one (usb3) is much more faster as well as more compatible adapter than second one (it’s limited to sd card speed and it’s not compatible with many laptops with built in pcie sd card readers).
